Question about Frigidaire FEQ1442ES Electric Dryer
My dryer won't stop running. Any advice? - Frigidaire FEQ1442ES Electric Dryer
    Sergeant:
    Champion:
  • 351 Answers
Timer may be bad
Posted on Oct 01, 2010
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
KNOBS WON T STOP TURNING, THEY WON T START DRYER
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 30, 2010 | GE DRSR483GD Gas Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
OVERHEATING DRYER
First make sure the vent is not blocked relieving air flow in back for examlpe remove exhaust hose and let it run with a window open for ventalation of course and let me know if this stops the problem
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
55 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
