Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
We purchased 3 Mr. Slim units for an open 1150sq ft. subterranean level classroom with one side walkway. one unit is attached to one condenser and two share another. All three units are set to the de-humidyfy mode. We set the ac to 78. The fan is on the 2nd setting. Problem: high humidity in the space. Difficulty maintaining comfortable temp levels. We just cleaned all the vents. We also have a fresh air exchange unit. What can we do to maintain consistent temp and humidity levels?
  • jmcinnis171 Oct 02, 2010
    We actually have 3 Mitsubishi Mr. slim split systems. The air exchange system is a Renew Air which was running 24/7 but now we are turning it off at night. The air system has a 6 to 8" diameter flexible duct with the fresh air intake underneath a large deck, pulling in air from deep in the corner (I think this is not a good placement). The room has real humidity problems. Even with all this equipment it is close to 70% humidity. The room had been cleaned prior via a environmental firm that removed mold and all drywall up to 5 feet, and floors. There is real concern that we will have more problems with mold and fungi if we don't get the humidity down to 44-55%.
    It is an ERV.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
First make sure a proper manual j is done on the space, then make sure your not bringing in fresh air while dehumidifying. Your either grossly over sized or slight under, you'll know if its over it will feel clammy, you can have mold issues and the equipment will most likely short cycle. If its under sized it will stubble to meet tempetures
Posted on Oct 01, 2010
  • 1 more comment
  • jmcinnis171 Oct 01, 2010
    Thank you. What is a manual j?
  • Zachary Oct 02, 2010
    a "manual j"is a load calculation. (all apologies for the industry slang). i have spread sheet i can scan in and send you but i would suggest call in a Free second opinion call with a company that employes Nate certified techs and ask them to run a load. Some companies will do this for free, some companies will charge a flat rate.
    Ideal humidity is between 45-55%Rh.
    each of your units is rated for 28400 BTU/hr meaning you have about 7.1 tons of cooling with 3 condensers but you said you have two, so you have about 4.7 tons of cooling capacity in your space.
    in regards to your fresh air system, were is this space located (the south, midwest, etc.) and is it a ERV or an HRV?
    Also is this space sealed, and what material is its construction?
  • Zachary Oct 07, 2010
    if you had a split system i would say to use a reheat coil such as a Lennox humiditrol (only certain systems can use these) , in your case you might want to invest in a stand alone commercial dehumidification unit. You should dehumidify without having to over cool your space. Mini splits can dehumidify but not the same as true dehumidification units or a forced air split systems with reheat.
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Mar 25, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim is dripping condensation into the room. I use this to heat and cool a 500 sq ft finished space over garage. I have been looking for troubleshooting guides but no luck. It is cooling the space,...
Firstly i would try and establish if the unit is on a gravity drain or a pumped drain.
1. If the drain is gravity it means the condensate water will flow with gravity normally straight through the wall, so check for blockages outside and inside, the unit may look clean but if it hasn't been serviced there may be a build up of dirt in the drain.
So try and locate the outlet of the drain outside (normally by the refrigeration pipework to condenser) and attach a wet hoover to it and make a good seal, this will **** any water/dirt out of the drain line.
2.If its on a pump, a small water pump which collects the condensate in a sump and then pumps it away when a float is activated. (Normally fitted if a gravity drain option is unavailable).
You can check to see if the sump is full and overflowing which is an indication the pump/float has failed and will req replacing by an A/C company. Or the PVC drain line is blocked with dirt.
The pump is either located behind the unit in the casing, or in the white trunk containing the refrigeration pipework
All the best
Jul 05, 2010 | Mitsubishi MSY-A15NA Split System Air...
Working on a pu24ek mr slim the suction is being pulled down to 5 psi yet the high side coming out at 140 psi on other side of cap tube i cleaned the screen going into evap distibuter possible restricted...
is the distributor inside the condensing unit on this system? it sounds like it is under charged also check the fan operation on the evap along with the filters and evap not dirty. if all is good i would say low on charge. i never had a restriction in a mini split. check the orifice in the condensing unit
Jun 05, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim Model PEH3VK no air in one zone.
The Zone controller needed replacing so I rang for a Serviceman
Jul 06, 2009 | Mitsubishi Heating & Cooling
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim 12,000 btu 110 volt
Sounds to me like yo have dirty condenser coils (outside unit) After this runs and gets hot it loads the compressor because it can not release heat out of the condenser coil it also may have a restriction somewhere on the high side that could cause this maybe in a txv or in a line filter.
Hope this helps Ya
please rate me
Jul 20, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
381 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
