How can I connect external speakers to a model PN42B400P3DXZA samsung tv? I have a powered stereo system and an 8mm-red/white cord. I attached the 8mm end to the external link plug in, in the back of the tv and the red/white end to the speaker system. It didnt work. I probably didn't do it right, so do i need a different tv or is there some other way to do this?
BingoDabbers
  • 102 Answers
SOURCE: Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Posted on Oct 07, 2007
  • 18 Answers
SOURCE: External Speakers
look for user manuals at http://www.user-manual-search.com
Posted on Nov 28, 2007
RFICKES
  • 51 Answers
SOURCE: Want external speakers for Sony TV Model KLV-S32A10
This is really easy. A pair of simple bookshelf speakers will do nicely. Simple speaker wire can be run to them, to extend whatever cable they have. If it's only screw terminals they have, so much the better.
You'll have to attach RCA plugs to the ends going to the TV, but that's easy.
Posted on Jan 04, 2009
SOURCE: No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
Posted on May 23, 2009
SOURCE: How to connect new HDTV to old stereo JBL speakers via TX-860 Onk
Depends on the kind of plyg in you have at the back of your stereo...
most strreo has phone, aux, tuner ,e.t.c..
If yours has any of this good, just plug your red and white audio out cable in any of this element listed above, then go to the front of your stereo and activate the particular element you plug into and increase your volume.
You will definitely here a sound.
Posted on Jan 28, 2010
What do I need to connect external speakers to tv
You will need an amplifier and depending on your tv you can run either red and black RCA leads or a toss link fibre optic cable to it.Then connect speakers to the amplifier(stereo)
Aug 30, 2014 | Televison & Video
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
Dec 23, 2013 | LG 42" 5700 Series LED HDTV - 42LN5700
I just bought a Philips Smart WiFi Bluray Player BDP2105F7 and I cannot connect it to my old tv which is a sony triniton, I have image but no sound. There are two outputs on the dvd player but I have...
Your white red yellow cord is a Stereo sound + video cord. The red and the white ends are for sound the yellow end is for video - if your TV is not stereo it may not have the red and white it may only have one in which case you need to find an adapter from stereo to Mono to fit your red/white cable ends into a single connection on the TV. Or you can buy a home theater sound system and it will give the TV its signal and it will keep the stereo signal and broadcast it through the sound system.
Sep 15, 2017 | Philips Televison & Video
How do I turn off my 550 Samsung tv speakers?
Take the audio out from the audio output RC jacks (Red and White). Then connect a headphone into the headphone of the TV. The speakers then will then get off. Never insert a dummy stereo jack, as the amplifier without speakers can get damaged (depends on the audio IC used).
Jul 18, 2012 | Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
No sound when using the TV
1- Find the two audio out female RCA jacks on your tv. One is red one is white. Some older tvs may not have any, if so you are out of luck.
2- Purchase a stereo patch cord (male x male RCA) long enough to reach the LG's Subwoofer.
3- Connect the red and white plugs to the tv output and connect the red and white plugs to the "Aux In" female RCA jacks on the subwoofer.
4- Select stereo input for sound on the LG's user interface.
You will be able to upconvert the stereo input to various surrond modes by studying the control manual.
Nov 29, 2008 | LG LFD790 System
Connecting to digital converter box
If your tv just has the yellow / white, this means the audio is MONO, wich means 1 speaker, not Stereo, just connect the white onr, and leave the red one out, or... you could connect the audio to your stereo!
Sep 27, 2008 | Samsung CXJ1364 13 in. TV/VCR Combo
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
