Question about HP Pavilion dv6000z Notebook
I have a HP pavilion dv6000. My screen does not turn on. It is black but if I wiggle the top a few and mostly many times, the screen will come on. It is at first distorted but is fine eventually. HP tells me that I need a new screen but I doubt it. A tech tried to fix it by working on the cable but only made it worse. Do you have any suggestions
Hp w1907 desensable
Posted on Oct 01, 2010
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
I have a HP Pavilion Lap top dv6000 AMD
You PC has crashed, you need to run a recovery (which will lead to format the partition and reinstall the O/s, that means all your data will be lost).
Restart the notebook and start tapping F11 key,you will come to Recovery Manager, click on Advance Options, and select System Recovery and click on next, select No without backingup the files (as this option most of the times fails). Click on next and wait for 30-40 mins for the reinstallation to get completed.
Regards,
Shrey
Oct 11, 2009 | HP Computers & Internet
Hp dv6000 black screen problem
tipical hp problem, if no warranty buy a new laptop "not hp", its called "the good old fashion hp graphic chip burned"
Jul 02, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 laptop support Linux 5 Enterprise Version
i tried holding 30 to 60 seconds and then turning the power on and the screen is still black screen...can anyone help me?
Jan 22, 2009 | HP Pavilion dv6000z Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion DV6000 with Vista
These are well known for VRAM failure and HP extended the warrany for an extra year regarding this model. If they refuse to repair free contact us back..
Jul 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
HP Pavilion dv6000z Notebook Logo
128 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
