Question about Cisco WAP4410N (WAP4410NLA) Pre80211n Wireless Access Point
Repeat WiFi from Livebox 2 with WAP4410N. How can I configure my WAP4410N to repeat the WiFi signal of my LiveBox 2? The SSID sould be the same? ... please, step by step. Thanks!!!
No Internet connexion between livebox 2zte and dap 1320 .
First connect to the Livebox (without the range extender) to see if you can access the internet. If you can get on the net there open your browser and type http://dlinkap.local in the address line, and set-up the d-link. the most common problem is the password on the router (the livebox).
For instructions for the D-Link go here;
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/Manual/DAP_1320_Manual_EU.pdf
For instructions for the livebox (translated into english);
http://translate.google.com/translate?hl=en&sl=fr&u=http://assistance.orange.fr/installer-la-livebox-2-zte-4665.php&prev=/search%3Fq%3Dlivebox%2B2zte%26rlz%3D1C1ASUT_enUS567US567%26es_sm%3D93
May 18, 2014 | Office Equipment & Supplies
I can't get my new Kindle to accept any of the numbers I can find on my Livebox. Which string of numbers does it want, please?!
So livebox is some sort of internet provider? Is it WiFi? If so then the kindle would connect just like any other wifi device like a laptop or smartphone. You need the SSID of the wifi device and the password.
Oct 24, 2013 | Amazon Kindle Fire HD
I am trying to set up a WiFi N Repeater but having no joy. I have followed the set up instructions and it states that the repeater is being updated then when complete there is nothing!! At lest I get an...
it sounds like your having an issue with the repeater not actually joining your main network correctly. do you know if your repeater is set up in bridge mode? also do you know what IP address you are getting when connecting?
Oct 06, 2013 | Linksys Wrt54g V1.1 Dd-wrt Tomato Wireless...
I am in france trying to connect my macbookair to a french livebox
Yes, you need to press button #1 on the livebox , which will put it into 'accepting new wifi devices' mode. This lasts about 1 hour.Presumably you've entered the wep key from the label on the bottom of the livebox into your macbook? don't forget it's got to be UPPERCASE characters!
Apr 27, 2012 | Apple Computers & Internet
Canot connect Ipad 2 to orange livebox.
You must connect via wifi to your livebox without problems. You may only go to Ipad settings and select the livebox wifi. I do not understand the problem.
Sep 16, 2011 | Apple iPad 32 GB WiFi Tablet PC
Is it compatible with livebox2 it does not respond with livebox2
Yes it is compatible with any livebox as long you have a wifi connection...You just nees to reset your phone and security key and reset your livebox and type in the security key of your livebox its always found under the livebox.
Apr 22, 2011 | Samsung Lands Phones
Print via usb with HP C3100 photosmart printer on an orange livebox printer using mac os10.6.2
As far as I know, a Livebox does not support an USB print server function, if that's what you're trying to accomplish. The USB port in the Livebox is for configuration only.
However, there might be a new model I haven't seen that has such a functionality.
Nov 12, 2009 | Computers & Internet
Wifi configuration
go to xda developers.com they will help you right away. There are so many connection configurations on this phone its amazing, I love mine.
Nov 06, 2007 | HTC S620 Smartphone
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Cisco WAP4410N (WAP4410NLA) Pre80211n Wireless Access Point Logo
192 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
