Question about Carrier TSTATHCP Programmable Thermostat Air Conditioner
I just bought a new house, so I do not have the owners manual for my Carrier programmable thermostat. A friend inspected my furnace earlier and gave it a quick cleaning. He left and after he left, I saw that my thermostat had an error message "E5". How cna I clear it and what does it mean? Thanks!
  • Zachary Oct 01, 2010
    is this a carrier communicating infinity stat (rectangle tall white with tiny blue led light in top left corner) ? i need to know cause e5 is an error code in more than one carrier stat, even some of the cheap baseline stats have little codes if they are
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Some times the easyest thing you can do is pull it off of the base it should snap off leave off for 2 min and then snap it back onto base
Posted on Oct 01, 2010
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
I moved into an apartment in a very old house; 2 floors, each floor has it's own oil tank and furnace. Problem: I bought a programmable thermostat, removed the old one, hooked up the new one, and now the...
Most programmable thermostats have a configuration setting for the type of system you are using. They also normally have a configuration setting for the Heating Cycle Rate, Assuming it is wired correctly, I suspect the problem might be somewhere in one or both of those two configuration settings. Let me know what you find or if you have any further questions. :-)
Mar 16, 2010 | Honeywell Programmable Thermostat Heater
We just bought a house that the thermostat had been removed and the wires were just coming out of the wall not labeled. The furnace is a Tempstar gas model 9MPT125L20A serial # LO13778617.As far as we can...
The Red and White wires coming from the furnace are the only ones that call for heat. the Green wire turns on the fan continuously, the yellow is for AC. If you have another wire color, it may be a Common wire and should not be used if your t-Stat has batteries. If no batteries, it goes to the C screw.
Sep 29, 2009 | Hunter Fan Company 5/1/1 Programmable...
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Carrier furnace blows heat constantly!
recheck your wiring iunside of the furnance around where yuou were working, you may have wired it wrong.
Dec 15, 2008 | Heating & Cooling
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
278 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
