Question about Maytag PYE2300AY Electric Dryer
My dryer is turning slow and not drying - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 01, 2010
Heat coils turn on and heat for a very short time then turn off briefly turn on again it takes 2 hours for a load to dry
Make sure your vent pipe is clear from the back of dryer all the way outside....A clogged or restricted vent is the most common cause of slow drying...
Nov 03, 2010 | Kenmore 62602 Electric Dryer
Slow dryer
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 28, 2010 | Kenmore 63942 Dryer
Dryer isn't drying as well as normal.Lint filter is clean.Doesn't seem to work any different on timed dry or auto dry.I have electrical exp. but no dryer exp.What should i check and how do I access it?
i belive you should check the vent hose from the dryer all the way to where it exits the house... that's usually the problem when dryers aren't drying as well as they shoud... lint wil start to cake on the walls of the vent and either create a complete block or slow the air down enough to keep it from circulating like it should
Feb 14, 2010 | Whirlpool WED5300S Electric Dryer
Brand new samsung dryer not drying fast enough took 2hours to dry and still damp. the dryer was on more dry, high heat,
try checking your vent exhaust
and vent tube
soometimes airflow is slowed by clogs and build up causing long dry times
Oct 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryer does not heat
check the heater and fuses.
Jun 28, 2009 | Roper RGX4634KQ Gas Dryer
Slow drying times
Check these things:
* The length of the dryer pipe and especially the wall flapper to be sure it moves ok and that it is not blocked by something
* Check the dryer vent line to be sure it isn't kinked somehere
* Check the dryer vent fan itself to be sure it is clean and not clogged or obstructed (I'm assuming it works)
* If all ok, you may have a bad thermostat or sensor that is causing the unit to turn off the heat prematurely
* Make sure the dryer isn't overloaded
May 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer slow to dry
Take the vent off the back of the dryer and dry a load unvented too make sure you don't have an obstruction in the line too the outside. If still takes too long too dry you might have a bad operating thermostat located on the blower housing it is a 4 terminal thermostat.
Jul 25, 2008 | Whirlpool Dryers
MY MAYTAG DRYER IS SLOW AT DRYING
Have you checked it for fluff. Also if the vent is blocked it wont dry properly.
Mar 22, 2008 | Maytag HYE3657A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
71 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
