Question about Toshiba 36A40 36" TV
My tv has white line straight across the screen 36"
SOURCE: 32A50
Vertical Output Capacitor
Take it to the shop, not very expensive.
Very heavy tv.
In home repair (armed robbery).
Posted on Mar 16, 2008
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
  • 71 Answers
SOURCE: White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
Posted on May 08, 2008
CAYPIANAN
  • 227 Answers
SOURCE: no picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Posted on Sep 30, 2008
bobjrdns
  • 84 Answers
SOURCE: 27" sharp has audio/no picture/ horizontal white line across screen?
bad vertical chip ic
Posted on Oct 19, 2008
Screen picture shrinking . Two wide white horizontal lines
Check vertical output circuits. They control the up and down deflection and when not working you get straight line across front of tube.
Aug 02, 2015 | Televison & Video
Good picture but a squigly line
Will you please provide more details> Is the line across the screen at its middle?
Jan 02, 2013 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
White lines running across screen from right to left
when there is a line from right to left it means a verticle amplifier is faulty, remedy
change a verticle amplifier IC
dont forget to check some capacitors (electrolitic for change of values)
this will solve your problem.
Apr 07, 2009 | JVC AV-36D303 36" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Toshiba 36A40 36" TV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
