Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Hi! I moved into a bank owned home with a hot tub that has a gas LAARS LITE 2 Teledyne heater. It is not working, so I had someone come out and check it. He said I need to purchase a pilot assembly before he can even tell if the heater is working. How do I know which one to buy?
  • 760 Answers
Go to www.laars.com and download a manual for your model. Get the model number from the heater, and look up a manual. If yours is a milivolt model, the pilot must be working to troubleshoot further. The manuals will be full of information.
Posted on Oct 01, 2010
Where do I find the heating element on my Teledyne laars hot tub? I have looked in and aound the control panel, Thanks
There is no such thing as a laars hot tub. They make heaters for pools and hot tubs. The laars is the heater. There is a chance that someone remote connected the thermostat to the heater which would be in your boiler room, or some other remote location, like near the pumps...
Dec 06, 2014 | Teledyne Laars Pool & Spa
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Conversion kit from natural gas to LP for a telstar heater on our hot tub
not adviseable from manufacturer but if you do you need new orfices and a gas valve and regulator for propane
Oct 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I need to order a gas valve for a Laars Lite 2 Model LG250P
Usually unless you are a Licensed Gas or Pool company the odds of someone selling you a gas valve to install yourself are slim to none.
Jun 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
249 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
