Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Is my trolling motor is pulling to many amps? The cable connectors are getting so hot the wire is melting.
  • 4,340 Answers
WEll, maybe, but what happens is the connectors loose their spring tension, teh resistance goes up, the heat goes up, looser....and fail. the only solution is to cut out all heat damaged material and install somthing heavier. Not always an easy task, but it will keep happening until you do.
Posted on Oct 01, 2010
Why does my motor guide 50 trolling motor fuse
It depends on how much current the trolling motor is supposed to draw when set to 5. If it's more than 40 amps, then you need a larger breaker. If it isn't more than 40 amps, then your current 40 amp breaker is weak and needs to be replaced.
May 13, 2014 | MotorGuide Electrical Supplies
Blower selector only works on #5??
The usual problem on these is the blower motor resistor.It is located by the blower motor on the passengers side under the dash.Just listen for the blower motor.You may have to remove a lower dash panel to see under the blower motor.Then just follow the 2 wire connector from the blower motor to the resistor.There are 2 screws that hold it in place.Just remove these and pull it down.You should see a burn mark on the resistor if it is bad.Also look the connector over real good.If the connector looks like it got hot and melted you will need to replace it also.You can get the connector with wires at the dealership.Hope this helps.Good luck.
Jan 11, 2011 | 2002 Pontiac Grand Prix
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Hot plug connector
if everthing else is hooked up properly and the battery connections are tight i would suspect a loose connection in either the plug or the receptacle. anytime an electrical connection heats up it usually means there is a loose connection or too many amps running through it than what its designed for. remember trolling motors should not be run out of the water for more than 30 seconds as they use the water to cool the output shaft at the prop. good trolling.
May 30, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Melting tube fuses
hi budd as its custom you may have the wrong size wire and to small of a amp try a bigger wire as the motor seems to be pulling to many amps for that cable and fuse
Aug 30, 2009 | Harley Davidson FXST Softail Standard...
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
Minn Kota tolling motor
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
Nov 24, 2007 | Minn Kota Maxxum 70 Universal Motor/Sonar...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
178 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
