Question about Tappan Ovens
Sometimes when i turn on my oven it doesnt get hot
  • Tappan Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 01, 2010
Oven takes too long to start or not at all
is this electric or gas? if it is gas and a newer model it has an ignitor that heats up that will then ignite the gas burner, the ignitor is bad or you may need to inspect and clean the gas ports on the burner as they can get cloged up over time, try the inspection and cleaning first. If it doesnt appear to be cloged then turn on the oven and watch the ignitor, if it doesnt heat up to be white hot then it is bad or going bad and should be replaced. if it is electric check to see if the heating element is working by turning the oven on and watch for it to glow red hot, if it doesnt then it will need to be replaced.
Sep 08, 2014 | Ovens
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 | Smeg Ovens
The oven stopped working today whilst cooking, now when you try to turn it on the indicator light doesnt come on and the oven doesnt get hot. . . . .is this the element???
hello,
this problem can be view from two ways
1. from the fuse or (power regulator)
2. from the element.
thank you.
Aug 08, 2010 | Ovens
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Apr 19, 2008 | Ovens
Ovens Logo
49 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
