Question about Roper RES7646KQ Electric Dryer
Roper model res6745pqo ser.ms4808124 dryer Dryer works except no heat
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
You have a bad heater element, or high limit/thermostat. Check your vent for restrictions also. A restricted vent will cause higher heat and thus reduce lifetime on these componants. Rich
Posted on Oct 01, 2010
Any help with reconnecting wires to heating element?
I would only be guessing but it was probably done wrong
Jul 14, 2014 | Roper Dryers
I have Roper Dryer model RED4340SQ1,SER -MU1914782,it will tumble but no heat
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced.
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
Hi, I have a Roper electric dryer (mod RED4340SQ1, SER MU2130244, Type 0433-ELE-2406026) that heats up when drying, yet does not heat up enough to dry the clothing. All other functions seem to work. ...
repairs should be performed by an authorized repair person. the heating element coil may be broken and grounding itself the the module housing. if so replace the heating element.
Jun 02, 2017 | Roper REX4634KQ Electric Dryer
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
My pully is laying in the bottom of my dryer. I need a diagram to know where it is to go. model number RES6745PQO
Many Roper Dryers use Whirlpool parts. Have a look at these two diagrams to see if yours looks the same:
If this helped, please rate it "4 thumbs up". Thanks!
Aug 01, 2011 | Roper Dryers
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Roper RES7646KQ Electric Dryer Logo
114 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
