Question about Hitachi 53UWX10B 53" Rear Projection Television
Blue color doesnt muve up
My tv 53uwx10ba hitachi is on manual comvejence adjusment, each time you press majic foccus 9 dots apears on screen, but when you want to adjust the blue color three of thees doesn't muve up. any idea what is the problem?
    Problem Solver:
  • 8 Answers
Hi there. sounds like a bad convergence IC. possibly a broken connection(s), parts are located on a large heatsink near the center of the main chassis, part number is STK391-110 for standard definition and STK391-570 for high definition, the location and part numbers can vary from model to model and year to year. hope this helps.good luck and be safe.
Posted on Jun 13, 2008
Hitachi 53UWX10BA HDTV adjusting color
Hi, Your tv model has a small light blue color button inside for manual adjustmnet mode. You will have to remove the front covering below the screen. its just attached with velcrow. Then there will be a centre wooden pannel with the the switching box screwed to tv front with around six screws.Open this panel and look to the left corner of the chasis boards in front of a small metallic box. Thats the switch you have to press to get into manual adjustment mode. use remote to adjust the colors. once done press it again to exist. Visit www.fixurtvs.com to find out more about tv FAQs. Thanks if you found it helpful.
Apr 29, 2009 | Televison & Video
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problem continued
Good Day;
When you activate the Mj focus the TV is restoring the data from the TV's digital circuits. So, you have the ability to change the IC's you can do this.
You need to go into the con service mode. Take off the front grill, remove panel, 6 - 8 screws. From the front there is a switch on the left hand side, it is small, white button with TV on. now you are in the service mode, using TV's remote adjust. Make sure you save dat. Go hit on line site get more info.
Goo0d Luck!
May 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blue doesn't seem to line up
Blue convergence IC is bad....change both,,,original number
Stk392-110 replace with upgrade Stk394-160E Hitachi part
# CZ 01341 ....also check B+ feed resistors for over-heating
................................T.
Jan 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hel whit mi hitachi
Remove speaker grill cover on tv lower front.Remove access panel.
Locate small blue push switch = activate convergence grid,then
use 2 & 8 , 4 & 6 , and enter along with adjuster arrows if I
remember right, then magic focus last..............T.
Nov 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
