Question about Goodman Heating & Cooling
Blower fan in the inside unit tries to turn on but wont. It can be turned manually and air conditioner comes on and runs fine. The " squirrel " cage spins completely freely and is not sticky or jammed. Is the motor bad or is it a run capacitor. Model number of inside unit is a49-15
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Sound more like the cap, but if the motor is raging hot, it could be the motor, another thing it could is improper voltage although less likely. But Goodmans/ do have this weird fan relay issue were they just bite it some times. I would say its either gonna be your fan relay or capacitor, if you don't have a meter i would just go to Johnstone or whoever is you local supply house that handles goodman and ask for the fan really and the capacitor, bring your model and serial numbers, the fan capacitor is likely no bigger than a 15mfd and no smaller than 5mfd but they will be able to know, it will probably cost you 30 dollars max most likely around 15.
Posted on Oct 01, 2010
Where is the capacitor on the indoor unit of a goodmemson
It's attached to the motor inside the squirrel cage (blower motor fan) or mounted to the outside of the fan
Feb 05, 2014 | Goodman CLJ30AR32 Air Conditioner
I have a New air 1400H and the blower fan has broke, can you tell me where to find replacement parts for this unit? I understand it has been discontinued for almost 5 years. Thanks for your help.Cont
You may have to remove the complete blower assembly, remove any dead squirrels, and take it around to various appliance parts suppliers to obtain a suitable replacement. You may need only a replacement motor if the squirrel cage is intact
Apr 30, 2013 | NewAir AC14000H Air Conditioner
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
Outside runs fine but inside squirrel cage motor fails
Go to the thermostat and place the fan switch in "on" and see if the fan runs. If it doesn't then check the circuit breakers. If the circuit breakers are on turn off the power and spin the fan by hand to see if it turns freely. If it does then check the fan capacitor. Let me know what you find.
Sep 26, 2010 | Weather King 10AJA3001AH Air Conditioner
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
Rheem A/C unit makes a clicking sound when
Shut down the unit and turn the power off. Take the cover off of the blower housing and feel around within the squirrel cage. It sounds like something may have been drawn up into the blower. Also it is possible that the blower wheel might have thrown a balance weight and caused the wheel to become unbalanced. It could also be the motor about to go out but since I can't hear it myself, I'm trying to cover all the bases.
Mar 22, 2009 | Heating & Cooling
Ruud Problems
ive seen this this year several times. first off take the combustion blowe loose from the ducting and look inside to see if theres any thing causing the blower to not run (water) what happens is that the flue gasses condense and run back into the blower then when it trys to start its binded.let me know if this does not solver the problem and we can get more into the furnance.
Jan 23, 2009 | LG LW1200ER Air Conditioner
Fan blower overheating
Sounds like your motor is bad check when it was installed all the units have a 5 yr warranty on parts but a HVAC contractor has to change it for the warranty
Dec 09, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
223 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
