Question about Philips 60PP9200D Television
When you turn it on all I get are 2 red light
Tv wont turn on it cycles through about 5 times then it turns off blinking 2 red lights at the bottom of the monitor.
Are you sure its two red lights blinking and not the one red light blinking and you can see it through the other window to look like two red lights? If so sounds like your lamp is blown. Open the back door and unscrew the lamp (2 phillips screws) and check to see if your lamp is blown.
Nov 02, 2010 | Toshiba 50HM67 50" HDTV
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
How do I fix my 360 for 2 red lights ? At first it had 4 red lights but I fixed that and now it has 2 red lights and I don't know what to do.
wrap in towels and turn it on let it run and overheat for a couple of hours turn off and leave for an hour to cool turn back on if no success its time to send for repair
Feb 18, 2010 | Microsoft Xbox 360 Console
Turn on x box 1min later i'm getting 2 red lights?
Yes 2 red lights is overheating, to fix it you need to stop the heat build up getting to the chips, you can do this yourself or you can send it in and they will fix it for you.
Jan 01, 2010 | Microsoft Xbox 360 Console
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
Aug 07, 2009 | Epson Stylus R290 InkJet Printer
2 Red lights for player1 and player2
Check the light on the power supply and if its orange that means that the console is on stand by mode, The light on the Power brick should be green when the console turns on. if the light turns red that means that the power supply needs to be replaced. call xbox support and check the warranty status of your 360
Mar 29, 2009 | Microsoft Xbox 360 Console
2 red lights on the ring of light
asdasdhgaiouhsdpgiohasd;ilgkhas;doilgk
Oct 28, 2008 | Microsoft Xbox 360 Elite Console
What causes the 2 red lights on xbox?
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire.
Oct 22, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Philips 60PP9200D Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
