Question about LG DLE5955 Dryer
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all is clean.
  • 489 Answers
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Posted on Oct 04, 2010
Dryer not heating
This problem could be one of many components , heater, t hermostat, thermal fuse, control board, wiring you would need to be noledgable about volt ohm meter to diagnose this problem . but try this turn breaker at panel off and back on this will reset the computer
Mar 24, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Oct 07, 2007 | LG DLE2514 Electric Dryer
Cooling light
The lights that come on are what the machine is going to do for the entire cycle. If you notice it will start to flash towards the end of the cycle. That is when it's actually "cooling" the clothes to try and reduce wrinkles. The dry light flashes while it's drying. As for the not heating at all you need to check for blown fuses or popped breakers.
Sep 24, 2007 | LG DLE2514 Electric Dryer
F1 light flashing with a picture of a wrench
See http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm, or http://www.fixya.com/support/t103415-fisher_paykel_dd_603_dish_drawer
Aug 24, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
LG DLE5955 Dryer Logo
546 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
