Question about Hotpoint NVL333EY Electric Dryer
Does any hotpoint dryers have a reset?
I recently moved my dryer and now it won't start
  • graham mcdonald May 11, 2010
    There are a number of reasons the dryer wouldn't start.Firstly start with the supply voltage 240ac, do you have breakers or fuses in the electrical panel?
  • 7,365 Answers
BEFORE WORKING ON ANY APPLIANCE BE SURE TO UNPLUG IT TO KEEP FROM BEING SHOCKED OR DAMAGING YOUR APPLIANCE
possible cause
1.no power---check fuse & power supply
2.loose wiring---check terminals & wiring
3.door switch---make certain door is closed properly to actuate switch
4.defective motor-- check motor
5.defective timer--replace
Posted on Jul 31, 2010
DRYER WON'T START WHEN START BUTTON IS PRESSED.
The fuse is located on the heater element which is bolted to the back wall behind the drum.
I have several home movies and repair pix on my DIY blogpage:
PAW PAWs DIY GE HOTPOINT DRYER Repair page
Dec 02, 2012 | GE DVLR223 Dryers
Unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Aug 17, 2011 | GE DVLR223 Dryers
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2011 | Hotpoint Dryers
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint dryer dlb2450bdlad. Bought new 15 yrs ago and has been in storage ever since. I tried to operate it recently. It works fine when engaging start switch but stops when switch is released.
the motor switch has seized you may try taking the dryer apart down to the motor and see if you can move the centrifical switch bushing it is behind the motor switch and has 2 springs on it move in the direction away from the switch several times and it may free up and be ok otherwise you will need to replace the switch
Apr 16, 2008 | Dryers
Hotpoint NVL333EY Electric Dryer Logo
532 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
