Question about OKI C8800dn Led Printer
How do you reset the okidata c8800 drums from the menu system
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Okipage 14e drum rest process
From memory, I think you enter maintence mode my power on when holding down menu key then arrow to drum reset. If not post back and I'll look at user manual
Posted on Jan 20, 2008
  • 54 Answers
SOURCE: Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Posted on Mar 16, 2009
komguy
  • 2306 Answers
SOURCE: Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Posted on Jul 03, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a Okidata b4600.
This may work. It will or should reset the entire printer and clear the error. This is basically a hard reset of the printer.
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" message
And that should do it. You should now either have no error messages or have access to the reset menu. You may have a problem with the little fuse inside the drum or the main board got a static discharge. Hopefully this will make it behave for you.
Posted on Feb 04, 2011
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
Have purchased some cartridges (compatable) for my Oki C5600 but i am unable to use them to to microchip.Is there a reset method or do i need to buy more chips?
Reset the Drum Counter:
a. Press the MENU 1/Menu 2 button while turning the
printer on.
USER MNT appears on the display.
b. Press the MENU 1/Menu 2 button until the message
corresponding to the drum you are replacing
appears. For example, if you are replacing the
magenta image drum:
MAGENTA DRMCNT
RESET
c. Press the ENTER/POWER SAVE button.
RESETTING briefly appears on the display.
d. Press the ON LINE button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | Samsung OKIDATA - OKI C5200n - Printer
I changed the drum and there's still a message saying order drum....is there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
Oki C6100 Laser Printer drum reset - from Fatal
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Feb 09, 2010 | OKI C6100n Laser Printer
My printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Jul 28, 2009 | OKI B6200 Laser Printer
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
Mar 16, 2009 | OKI C5100 Laser Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
8. Restart printer.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Jan 18, 2008 | OKIPAGE 14e Led Printer
OKI C8800dn Led Printer Logo
572 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
