Question about Hitachi 53UWX10B 53" Rear Projection Television
Problem continued My hitachi 53uwx10ba has a blue shadow at the right and green shadow at the left of each object, I replaced the two ic's, for $3.85 each on e-bay,but it didn't fix the problem, I did the manualy comverjence, now each time I press the majic foccus on the front, 9 dots apear on screen, at this time you manualy muve the colors at righy spot, but 3 dots (lower left, center, and upper right)the blue color dosn't want to muve up. do you think is better to change the ic's for better quality? or what else I can do?. Also what is the procces to get magic foccus on the tv?
  • 927 Answers
Good Day;
When you activate the Mj focus the TV is restoring the data from the TV's digital circuits. So, you have the ability to change the IC's you can do this.
You need to go into the con service mode. Take off the front grill, remove panel, 6 - 8 screws. From the front there is a switch on the left hand side, it is small, white button with TV on. now you are in the service mode, using TV's remote adjust. Make sure you save dat. Go hit on line site get more info.
Goo0d Luck!
Posted on Jun 13, 2008
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Double shadow green and pourple
check the 3.3ohm resistors right next to the convergence ICs. Also the ICs for 3.49 are most likely cheap chinese ICs and not origional sanyo ICs . I have seen the cheap ICs go out as soon as you power up the set the first time.If you need more assistance please let me know.
May 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hit 53UWX10BA
convergance ic bad
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 46in rear pro
You have bad convergene output IC's. There are 2 in the set and we always replace them both because the one that s not bad will likely fail in ashort time causing you to have a 2nd labor bill.
Aug 27, 2007 | Hitachi 46BX01B 46" Rear Projection...
Green alignment
One of your convergence output IC's has burned out and needs to be replaced.
Jun 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
