Question about Panasonic KX-TG2257 Cordless Phone
We are away from our principal home. My wife called to access phone messages and inadvertently must have turned the answering system off. Is there a way to remotely turn the answering system ON? Thank you
    President:
  • Panasonic Master
  • 860 Answers
Turning on the answering system
Call your unit and wait for 15 rings.
•The unit will answer and the greeting message will be played.
•The answering system will turn on. Hang up or enter the remote code for other
options.
•When turning on the answering system using a rotary or pulse service telephone,
you cannot enter the remote code for other options.
Posted on Oct 01, 2010
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 2 Play Incoming Messages
0 then 7 Memo Record/Stop*
0 then 3 Skip a Message
0 then 8 Greeting Message Record/Stop*
0 then 4 Delete a Message 0 then 9 Answering System Off
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
Feb 28, 2011 | Uniden Cordless Phone EXAI985
I am away and want to retrieve my messages on my home phone
Call your Number let the machine answer and press the star button on the phone you are calling from. That should then let you press in your pin and access your messages on the machine.
Nov 12, 2010 | AT&T 1717 Digital Answering Machine
Access messages while away from home
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual and the remote access instructions.
Aug 20, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
* For the Repeat a Message function, press 0 then 1 within about four seconds to
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
2) During the greeting message, press 0 and enter your PIN code.
stored in memory. Then you hear "To play incoming message, press zero two.
Command Function
If you forgot to turn on answering system the directions for that are here:
number of messages stored in memory. You hear "To play incoming message,
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Picking up messages remotely
Try this...
Remote Operation
Command Function
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
Additionally, you can turn On or Off your answering system remotely.
1) Call your telephone number and wait for the system to answer. If the answering system is
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
5) After the command has finished, you hear intermittent beeps indicating that the system
chart above.
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Panasonic KX-TG2257 Cordless Phone Logo
101 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
