Question about Poulan Garden
Need to attach starter pull cord on a poulon leaf blower BVM200VS
I had the same problem. I opened up the blower by removing all the Allen screws, 4 mm wrench.
Then pull the motor, need a Torx T-25wrench. You then need to wind up the recoil which is part of the case on the motor side. Wind it up all the way and then put a screw in the slot that is in the recoil.
Thread the cord through the tube through the triangular hole in the white disc. Type a big not that won't slip through the hole. Pull the screw that is holding against the spring.
Remount the motor, wiggling it until it slips into place. Make sure it ratchets.
Reassemble and you shold be good to go. Only took me 3 attempts to get it right.
Posted on Nov 24, 2010
Can I get a trouble shooting guide for a Poulan Pro leaf blower bvm200vs
the owners manual, available online has some trouble shooting tips...
Oct 18, 2014 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Why won't my Poulan leaf blower pull cord turn motor over?
If the recoil is spinning free and you feel no resistance either the engine is damaged or the recoil dogs are not engaging. Fixing either of these at a shop will likely cost more than buying a new unit.
Jul 29, 2014 | Poulan Bvm200vs/bvm200le Blower/mulching...
Poulon-Pro leaf blower manual
If you know your model number (i.e EVB160 etc) you can use this link:
http://www.poulanpro.com/node4043.aspx
enter your model number and download it.
If you do not know your model number
click on products same link, then click on blowers (not snow throwers) find your model then go back to the users manual download.
Thanks for using fixya.
Feb 14, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Weed eater Feather Lite Blower - replacing pull cord -can't figure out how to get to it
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Nov 21, 2009 | Garden
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Repalce cord on gas blower
MAKE SURE YOU HAVE THE RIGHT SIZE CHORD FOR THAT STYLE,MUCH SMALLER THAN MOWER STYLE. ALSO PROBABLY HAVE IMPROPER TRACKING OF ROPE. TRY PULLING COVER BACK OFF AND MAYBE KNOT GETTING CAUGHT UP IN FLYWHEEL FROM ROPE
Jul 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
858 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
