Question about Brother SE-270D Computerized Sewing Machine
My thread keeps getting knotted up underneath. I have followed all the trouble shooting procedures and it still won't work.
    Genius:
  • 1,788 Answers
Usually it is the top threading, tangled thread or a bent needle that causes that problem. You can call Brother at 1-877-276-8437 and maybe they can suggest something else to try.
Posted on Oct 01, 2010
I HAVE MODEL 12312 AND CANT GET THE BOBBIN TO WORK, THE BOBBIN KEEPS GATHEREING UNDERNEATH MY WORK. ANY SUGGESTTIONS
Please check your fabric results. Is it the bobbin thread that is accumulating under the fabric, or is it really the top thread that is globbing and knotting under the fabric. Usually, thread mishaps under the fabric are the result of an issue with the top thread.
ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disks so the thread will seat properly. Use a brand new needle. Start out with the upper thread tension set midway between high & low numbers, although this can be tweaked.
If it is in fact the upper thread, then here are some suggestions:
Sewing Machine Thread Bunching Up Here Why
Troubleshooting Thread Nesting Sew Toot
Nov 29, 2016 | Sewing Machines
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
Tension for brother xl2120
try removing needle thread completely and re threading the machine with pressure foot down. as sounds like top tension not working or simply too loose
Feb 08, 2014 | Brother LX3125 Sewing Machine
Thread is catching AND WON'T SEW
The timing is off which is causing your trouble. I know someone who had that problem and she ended up bringing the sewing for service.
EJ Kudelka
Mar 16, 2012 | Sewing Machines
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Problems with Singer 2732
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
107 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
