Question about Toshiba Televison & Video
No picture or sound. blinking power light - Toshiba Televison & Video
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: tv no sound no pictures power light blinking
There are a couple of things you could check on this one if you have the equipment and are somewhat skilled in electronics.
Take a test meter if you have one, if not try the local radio shack. Unplug the set and remove the back. Locate F802 a small pico fuse in the SMPS 4a/125v. Test this for open - if open replace it...
Next locate Q472 ( 2SC1740 ) a common NPN amp transistor which will cross to NTE85 in a pinch. This transistor is in the shutdown circuit and if it's failed usually causes the conditions you have there..
Try at least these, and if anything here sounds the slightest complicated take it to a shop - it should be a rather inexpensive repair...
Bill
Posted on Nov 17, 2007
ctf1800
  • 4402 Answers
SOURCE: no picture no sound and power light blinks.
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
other wise i would replace the convergence ic first.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
ginko
  • 19396 Answers
SOURCE: red light blinking no picture no sound
tart checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
Posted on May 22, 2009
freetek
  • 5568 Answers
SOURCE: power light blinks but no picture or sound
The power light is using the same small 'always on' power supply that keeps the infra-red receiver for remote functions alive too. It is likely that the main power supply is sick and will need repair or replacement.
This is probably a separate board (these are often outsourced to specialty companies) and should be user replaceable once you identify it.
What you can do is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr.(or company linked below) and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload and the power supply for the backlight may be at fault.
Possible board source:
Jimmy's Parts
Posted on Nov 23, 2009
Testimonial: "great information! thought it might be power supply but needed expert view and advice. Thank You very much."
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
