Question about Akai LCT3285TA 32 in. LCD Television
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
    Guru:
  • 417 Answers
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Posted on Oct 01, 2010
  • 3 more comments
  • scott spaid Oct 01, 2010
    the power cord goes all the way into the tv itself and all it does is come on the blue screen then flashes to a black screen for about 2 seconds then turns off and the green power led light on the front goes from green to red then off
  • T-Comtech Repairs
    T-Comtech Repairs Oct 01, 2010
    pull the power cord out of the back of the TV keep pressing the power button until all the power is drained out,then keeping the power cord switched on at the wall plug it back in to TV you'll here a little popping noise as the plug hits the pins but it's fine. wait a couple of seconds if nothing comes on the screen press the power button on the front panel ONCE.
    try this a couple of times untill it comes on
  • zencomp Nov 14, 2010
    I have the exact same problem with mine.. Did you get it resolved? Thanks for any help.
    Hello. I have the exact issue with mine, did you get this resolved? thank you for any help.
    I have the exact same problem, did you get this resolved? Thanks for any help.
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Turn it on screen with blue AKAI comes on breifly then cuts right back off smelled like a transformer or something burned out
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Akai+LCT3285TA+
Please post back what you find.
Dec 17, 2009 | Akai LCT3285TA 32 in. LCD Television
Where can i get power supply board akai lct2016
that does not sound like a power board issue in my travels it aways is the mainboard . try shopjimmy.com or andrews Electronics or Tops Electronics in Haverhill ma
Dec 02, 2009 | Akai LCT2016 20 in. LCD Television
Authorized Repair Centers for Akai Flat Panel TV
first try to reattch all coneection to your televison.
then open the back side cover of your tv then reattch all connectiuon there .
Also clean dust from all circuit.
Apr 23, 2009 | Televison & Video
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
AKAI WONT POWER ON!
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
Powers on, screen flashes Akai screensaver and then shuts off
Take the unit into the service center - have the service center diagnosed the problem - they will order the part - but the parts are not available - DONT WAIT - The manufacturer must exchanged the unit because the the manufacturer must provide the parts for up to 5 years by law after the the tv is manufactured. Have the service center provide you with a workorder stating the television is not repairable because the parts are not available - then call 800-726-4405 - they will start hte process to exchange the televsion - LONG PROCESS to get an exchanged television
Feb 24, 2008 | Akai LCT3201TD 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai TV troubleshooting
I have the same problem. My Akai 27" flat screen shuts off inconsistantly. Sometimes it will stay on for hours and then we have to turn in on every 2 minutes. It seems to be getting worse. Is there anyone who has found a way to fix this?
Oct 19, 2007 | Akai LCT2715 27 in. LCD Television
Akai LCT3285TA 32 in. LCD Television Logo
147 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
