Question about Dryers
How to test/change heating element in stackable dyer
  • Keith Holmes
    Keith Holmes Jul 17, 2008
    dyer want heat
  • ckccooper Dec 16, 2008
    need to change heating element
    President:
  • 1,314 Answers
Pop me and email at b4829@yahoo.com and ref stackable drier oh dont forget my 4 boxes
Posted on May 26, 2008
2 Suggested Answers
  • 3074 Answers
SOURCE: NEED TO INSTALL HEATING ELEMENT
This is it, Good Luck Tim:
http://www.partselect.com/dryer+replace-heating-element+repair.htm
Posted on May 26, 2011
No heat for whirlppol steam dryer
check the heater element, it may need replacement
Dec 22, 2013 | Dryers
NEED TO INSTALL HEATING ELEMENT ON MODEL FEX83ICSO STACKABLE DYER
May 26, 2011 | Frigidaire Dryers
Frigidaire LC-240H-W*2 change heating from 240 to120
the heating element is always 120 volts.
the two lines from the breaker box to the dyer consist of two 110 volt lines which one runs the motor and one for the heating element
May 21, 2011 | Dryers
Where to locate dryer circuit, I think fuse needs changed. Dryer runs but no heat. Stackable set, dryer on top.
kill the power by unpluggin of kill breaker get acess to inside usually from back check the thermal fue or themosats or heating element.. clean your venting as well there might be a tech sheet inside but yea start there.. u can test those with a meter for contunutiy or call for service
Jan 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Dyer is not getting hot
If the dryer is not heating, check for a faulty thermal fuse or heating element. The thermal fuse is located just inside the rear of the unit, and is usually attached to the exhaust duct. It is about one inch long. The thermal fuse and the heating element can be tested using an ohm meter or multimeter. Check for continuity. If there is none, the component is defective. Sure hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Dryers
My dyer will not cut off
I would suggest checking to see if your start button is stuck
Jun 17, 2009 | Dryers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
474 people viewed this question
Top Dryers Experts
