Question about Samsung Dryers
My Samsung dryer, #DV330AG, purchased new in June is not tumbling. It was working a day or two ago, but when I go to turn it on now, it makes sounds as if it is running but the drum is not tumbling. please respond ASAP to schmhaus@charter.net
Amigaman
  • 248 Answers
SOURCE: tumble dryer
No. What brand is it? Is it running but not tumbling? Is it gas or electric? What model number. Let me know!
Posted on Nov 16, 2007
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
  • 9 Answers
SOURCE: Dryer not tumbling
only one thing it can be if you say burner is coming on. You have a broken belt.
Posted on Mar 27, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
  • 57 Answers
SOURCE: Tumble dryer not working
sounds like a broken belt ;it has to be un plugged from the power source . most belts can be accessed thru the panel on the back o f the dryer.
Posted on Jun 12, 2009
Miele t224 tumble dryer
Yes that is what it sounds like. Maybe lose or a wire barely making contact
Apr 06, 2014 | Dryers
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
With new electric dryer, samsung DV330AG, do I need to use a special plug with copper connectors? The plug that I have has what looks like brass connectors.
Hello, W/D here.
If it has a tag on the cord that says UL listed, it should be fine. If the plug does not meet a national standard, replace it with one that is.
Best regards, --W/D--
Feb 08, 2011 | Samsung Dryers
Hi. DLEX8377WM - no heat...dryer tumbles and there are no errors, but no heat. Happened a few months ago, but started working again.
sounds like the heating element is out, you can disconnect the vent hose turn on dryer and see if heat comes out.
Aug 03, 2010 | LG Dryers
My maytag neptune dryer makes a buzzing sound but does not turn, then later in the day, it will start just fine and run, until later in the night and then it won't . does this mean I have a loose belt?
its either a loose belt, (very easy to sort out as most tumble dryers use the motor on a pivot to tension the belt.)
if its not a loose belt its most likely to be the carbon brushes inside the motor that have worn down and are now making poor contact with the motor itself.
if your not confident to have ago at fixting these yourself, most repair shops should be able to-do this for you in 10 - 20 mins tops and it should not cost a fortune either.
Dec 29, 2009 | GE DBL333EA Electric Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Dryer heats but won't tumble
Assuming, the timer is ok and that you can hear the the dryer motor running, it sounds like a broken belt. These kind of failures generally occur suddenly - one day it works, the next day it doesn't.
May 03, 2009 | Dryers
The button on the tumble dryer wont stay in. if we hold it the tumble dryer will work
sounds like the switch has gone?? maybe buying a new switch will help or if its part of the front board then its gonna cost a bit more.
what make and model is the dryer ???
Mar 30, 2008 | Dryers
Candy condensor tumble dryer cc23ox
It bee cheaper replacing it as is very comon on these that the drum fails...
Nov 27, 2007 | Candy CDC266 Dryer
Dryers Logo
178 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
