Question about Mitsubishi VS-4543 45" TV
I have a Mitsubishi VS-4543 that has no power at all.
    Genius:
  • 1,622 Answers
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. They are always bulged or leaks capacitor.
Now, if your LCD set is still under warranty I would suggest to use it and let the professionals handle the problem for you. But for the rest of the LCD TV owners that their warranty had expired and want to save some money, this would be the best route.
Here's what you need for this problem to be solved ,Screw driver, Soldering iron(40watts+), Desoldering braid, Soldering wire, and capacitors.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
Important Notes:
power supply capacitors has 10v installed on the board and it is attached to a 12v bus which is causing to bulged. its going to get bigger or burst. And that's why our LCD sets end up with bulged or leaked capacitors)
Look at the bad capacitor and get the right information from it, remember uF, voltage and temperature. Mine, I only change 2 capacitors. It needed two 2200 uF, when I first saw my power supply it was really easy to spot the bad caps. Some LCD owners did went ahead replace all the capacitors on the power supply to make sure. I would not recommend changing all the capacitors because to me it was time consuming
Few things to take note, always make sure you have the right polarity. Negative part is where the colored stripe on the capacitor. If your looking at the image above, it would be the copper colored stripe. And if you are looking at the two connector wire of the capacitor, the negative wire is the short one. On placing it on the board make sure negative to negative and positive to positive. By this time you will be ready for soldering.
Hope this help in solving the problem.....
Posted on Oct 01, 2010
Blank screen and no audio on Mitsubishi vs 4543 when ps3 is connected through rca cables. other electronics work fine.
Check and replace the main power regulator [SMPS] board to your TV. Contact any service technician, or the authorized service center for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 12, 2014 | Mitsubishi VS-4543 45" TV
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
VS-4543 Mitsubishi 45" TV
Replace red convergence IC,both IC's for solid fix
Jan 12, 2008 | Mitsubishi VS-4543 45" TV
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Aug 05, 2007 | Mitsubishi VS-60607 TV
Mitsubishi vs-4543
Most likely the convergence output IC has shorted out and has overloaded the convergence power supply, which has stopped working. The computer senses that the convergence power supply is not running and shuts the set down. The convergence IC should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Aug 04, 2007 | Mitsubishi VS-4543 45" TV
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
