Question about Sony CDP-CX335 300-Disc CD Changer
Sony MegaStorage CDP-CX335 300-Disc CD Changer. I found one loading belt broken... after replacing both (2) loading belts... the table now stops short one slot shot to play a CD... what I mean is... if a CD is in slot #2 ... the white plastic arm is lined up to pick up the CD on slot #1... I can move the table manually with my hand one more slot and then it senses the CD and picks it up and plays it... so it seems to be stopping short by "one slot"... no matter what number I select. Is there a electrical adjustment to move it over one more slot? I do not think that the gears jumped out of timing...
fairlane
  • 50 Answers
SOURCE: sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
Posted on May 04, 2007
welcomejee
  • 10594 Answers
SOURCE: Rotary table on Sony CDP-CX225 200 disc changer will not rotate
I think CD Mechanism needs service and might required belts replacement.
You need to get service manual of your CDX-C225 model to do this job as manual contains all technical info about mechanism etc.
Posted on Nov 07, 2008
tech240
  • 169 Answers
SOURCE: My Sony MegaStorage CDP-CX455 400 Disc changer
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
Posted on Aug 09, 2010
gokomets
  • 120 Answers
SOURCE: both drive belts are broken.
Easier to buy the belts by "size" but there are several parts suppliers on line can sell
you them by the model # !
Posted on Apr 26, 2011
walesarumi
  • 6993 Answers
SOURCE: Sony MegaStorage CDP-CX355 300-Disc CD Changer
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is refusing to play any more CD....
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens. You can add very little liquid to the cotton board like mentholated spirit and dry the lens with another cotton board that has not liquid on it.
If non of the above solves the problem, then it means the lens is weak beyond cleaning. Know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all CD's again without any problems.
I hope you understand the above.
Regards.
Posted on Jun 15, 2011
Sony CDP-CX455 carosel is getting stuck when trying to go to a numbered disc. I hear belt screeching and the carosel goes back and forth a few disc, but not where it suppose to go.
The belt is stretched/worn and needs to be replaced. In some cases an O--ring can be substituted. Got mine at a hardware store that still carries plumbing supplies.
May 18, 2016 | Sony MegaStorage CDP-CX455 400-Disc CD...
Sony CDP CX300...new belts, mechanism gets disk, places it in front of the spindle but the spindle doesn't move toward it and the disk is put back in carousel.
These models often get broken loading parts in front of the pickup assembly. If you could take a good picture of the front of the mech, I may be able to identify what is broken.
Sep 01, 2015 | Sony MegaStorage CDP-CX355 300-Disc CD...
The cd changer wheel if not turning anymore.
The belts last about 15 years, less depending on usage. Sounds like it's time for a belt replacement. Check out softduds on eBay, he can replace belts and adjust these players, he has lots of experience.
Aug 25, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd player indicates Table Error
The belt in the back of the player under the hood is either broke or has came off the rollers. You will need to take the top off and replace the belt a rubber band will work as a temporary fix till you can order a new belt.
May 28, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
I am getting a table error message
Hi, the error is because the cd changer is not turning, something block it! or ther is an audio cd inside that blocks the normal function or change the "rubber belt" that the motor drives for the disc system changer!, an other problem could be that is not reading the audio cd's.
If you do chek this shure you solve this problem
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Jan 16, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Sony CDP-CX335 300-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
