Question about Maytag Refrigerators
I found some water under my refrigerator and I can't determine where it is coming from. It's a side by side. It's the side with the freezer that I found the water. I have the water line shut off before it gets to the refrigertor. Where would the water be coming from?
    Sergeant:
    Champion:
  • 351 Answers
Check the icemaker water line from water valve to icemaker make sure deforst drain dosnt have a hole in it some where
Posted on Oct 01, 2010
I have a small amount of water appearing on the floor, on the right side under the freezer drawer. I do not see any water under the fridg. I've also found ice in the freezer on the right side. What might...
It appears you may have a blocked or frozen defrost drain. As the repair involves a complete teardown of the freezer compartment, you may want to contact a qualified Samsung technician to make this inexpensive repair.
Jun 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
Water is overflowing at the bottom of the freezer
Blocked drain line for when the freezer goes into defrost.
Apr 30, 2010 | Maytag MSD2756G Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Kenmore top freezer/frig has water coming out underneath applianc
THE HOSE THAT COMES FROM THE FREEZER TO THE TRAY EITHER ISN,T LOCATED IN THE RIGHT POSITION OR IS DETACHED WHERE IT COMES OUT THROUGH THE WALL
Aug 11, 2009 | Refrigerators
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
155 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
