Question about Coleman Powermate 024 0179CT 2 In 1 Nailer/Stapler Kit
Just bought a colman powermate compressor and nail gun/stapler. the nail gun/stapler model is 024-0202. I've oiled the gun, dropped the nails into the chamber, slammed it shut and tried to use it, but no nails come out..... I've removed the nails, and reinserted them... the compressor is working properly.... plenty of pressure. The gun leaves imprints of the impact onto my test wood, but no nail comes out... I'm wondering if maybe the nails arent actually engaged inside the gun as the side window does not register the amount of nails in the unit. Also, you can hear the nails sliding back and forth....
3 Suggested Answers
  • 1274 Answers
SOURCE: Where do I get parts
Hi, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa....John
Posted on Dec 04, 2010
  • 1388 Answers
SOURCE: I have a power fist stapler nailer 8042509 which
Travel of driver blade /striker is controlled by lower bumper. Remove driver blade and cylinder to examine the bumper. It should be complete not cracking or chipped. If worn replace to solve problem. If it looks to be in good condition, add thin piece of rubber under the bumper to space driver out a bit. Use piece of inner tube or similar and make small hole to pass the driver blade. Other solution would be to actualy grind the end of the driver a bit. Good luck
Posted on Apr 08, 2011
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How to use?
What is the model of your Stanley Gun? What nails are you trying to load?
Tracy
Solent Products Air Nailing and Stapling Supplies
Mar 24, 2013 | Stanley Bostitch Nail Gun
The nails will not drive into the oak flooring! the compressor is at 100psi and the nail gun mis fires or when it does fire it only drives the nail 1/4 inch into the flooring. It is a Akuzuki x-799
I am not familiar with that name of nailer but when I have run into that problem it was because of too much oil used in the gun. If so this will have to be cleaned out. You do not have to oil a gun every time it is used if not used consistantly for long periods of time. Also are you using the proper guage nails? Something to consider hope this helps.
Apr 25, 2011 | ProSeries Akuzuki Contractor Pro Series...
We just bought the finish nailer and there are no start up instructions. We are not sure if we can just fill the compressor and start nailing away or if we have to do something first before actually using...
no your fine!!! put the supplied oil in where the hose attaches to before use!!
also be sure to drain air copmpressor daily through bottom valve rusting can occur!!
have a great day!!
Feb 15, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Where do I get parts (driver) for powermate nail gun?
Dec 04, 2010 | Coleman Powermate 024 0179CT 2 In 1...
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
I have bought a tacwise 140EL nailer/stapler. I
Turn the gun upside down and pull out the black plastic loading thingy, drop the nails in the left hand side of the gun,press against side with finger and slide black loading bit back over top of nails-hey presto!
Oct 13, 2009 | Tools & Hardware - Others
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
Coleman Powermate 024 0179CT 2 In 1 Nailer/Stapler Kit Logo
224 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
