Question about Microwave Ovens
I have a delonghi magnifica rapid cappuccino coffee machine, but have lost the manual. How do I descale it please?
  • 3,083 Answers
Here was an answer from wholetottalove.com:
DeLonghi recommends using Durgol, and you should descale/decalcify about once every 3 months depending on your water quality. Some DeLonghi machines even have built-in message systems to notify you when it is time to descale. You can purchase Durgol by following the links below. Durgol Express is ideal for coffee makers, and Durgol Swiss Espresso is recommended for espresso machines.
This site says you can use citrus based descaling solution to the directions on the bottle.
Good luck, and hope this helps.
Posted on Oct 01, 2010
User manual required for DeLonghi Magnifica ESAM 4200.s
here is general technical data for the unit
http://www.delonghi.com/uk_en/products/esam-4200s/
and here is the manual!
http://www.filesavr.com/YE9UE5DM5WIBGUV
Hope I helped, thanks for using FixYa!
Aug 08, 2011 | Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
I need the DeLonghi Caffee Figaro manuel. Please let me know how I could get it.
Hi and welcome to FixYa, I am Kelly. DeLonghi provides manuals for all of their products on line. Their global website is http://www.delonghi.com after clicking the region that you live in search for user guide. You must have a model number vs a name of your coffee maker (example) BCO110 to download your manual. The model number should be on the bottom of the coffee maker.
This was my best guess for your model since you did not provide one:
http://web1.dlservice.org/dlservice/dataload/istruzio/GB-573674.pdf
You can use this page to search for a manual by model number or product code:
http://web1.dlservice.org/dlservice/ext/delonghi/cercalibretti.php
Thanks for choosing FixYa,
Kelly
Dec 28, 2010 | DeLonghi Microwave Ovens
My DeLonghi Magnifica S ECAM23210 coffee machine is leaking water from the back.
I received the exact same machine for Christmas yesterday and had the exact same problem! I took it back to Williams Sonoma today and exchanged it for another one and I just started it up and have the SAME problem! Water comes out the bottom onto the counter - never even makes it up through the machine. This must be a batch of lemons - I guess I'll call Delonghi tomorrow.
Dec 25, 2010 | DeLonghi Microwave Ovens
I need a manual for the DeLonghi Pump Espresso & Cappuccino Machine. ECO310.OB
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 15, 2010 | Microwave Ovens
Need owners manual for DeLonghi DCF212T Have a display model without a manual
This question was posted under the "Microwave Ovens" category. However, the DeLonghi Model Number you provided cross references to a COFFEE MAKER. If this is what you are looking for, here's a link to managemylife.com website:
http://www.managemylife.com/mmh/owner_manuals/72694/DeLonghi-Coffeemaker-DCF212T-DCF210TTC?brand_name_search=dcf212t
You can download, or print a copy of the manual for FREE.
If this is not what you are looking for, could you please verify your MODEL NUMBER to ensure it is correct? Please post back and let me know, if you need further assistance.
Nov 03, 2010 | Microwave Ovens
Microwave Ovens Logo
208 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
