Question about Vacuums
When water is added to the reservor, only half comes when brewing. I have to go through steps again to get the remaining water.
  • Vacuums Master
  • 3,083 Answers
Not sure what kind of machine this is, but I would think it could be a couple things. The machine could be jammed up by deposits, and need a descaling. Use 1/3 solution of white vinegar to descale normal coffee makers- the expresso machines usually recommend a commercial descaler. You could also have a slightly cracked water feed line, so check that.
Depending on the design of your unit, the heater coil could be cutting off when it gets too hot, due to a thermal sensor or other protective device.
Good luck, and hope this helps.
Posted on Oct 01, 2010
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
Coffee pot is not brewing.. it says to de-scale
Clean any residual coffee grounds from it and then pour in a 50/50 mix of water and white vinegar, and brew. Then repeat with just water to rinse.
Aug 16, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
The water is not going thru to make the coffee. You can hear it wanting to brew, but no water is coming out.
look inside the coffee pot and make sure that is connected and the tube is in the water so it can bring the water up into the coffee grounds.
Feb 22, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
