Question about HP Office Equipment & Supplies
My printer will not turn on. the power cord on the back plug in has a green light and this is lit.
  • 857 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
if doesnot then
Removing and reseting the print head worked may work. Remove the cover and the cartridges then the print head, Clean then and reinstall them and see if it works.
Else printhead may need to be replaced.
Posted on Oct 01, 2010
How do i fix my dell 2135cn printer
If the power button is lit then there is power going to the printer. However, if there is no display coming on then there could be an issue with the system board on the printer.
We can try doing a manual reset to see if that helps.
Unplug the power cable from the printer.
Press and hold Start button(Green button) and Cancel button(Red cross) while you plug the power cable back in.
Let go of these buttons once the power light is lit and check if the display comes back on.
If the issue remains the same then the printer needs to be replaced. Please let us know if this helped. Thank you.
Oct 12, 2016 | Dell 2135cn All-In-One Laser Printer
HP Photosmart 7280 all in one. When power cord plugged in, printer will not turn on
Sounds like it could a power supply problem inside the printer or a motherboard component failure. It needs to be taken in for servicing. There is no way to tell what the problem is without an internal review.
Apr 28, 2014 | HP Photosmart C7280 Printer
X9575 won't power on
Check with Lexmark to see if there is a reset button for unit
Aug 22, 2017 | Lexmark X9575 InkJet Printer
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have a new printer and it has no power
Plug the printer straight to the wall power outlet, bypass any surge device or power strips. If still no power. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. With the power cord still attached to the power adapter and the other end plugged in to the wall power outlet, the LED, found around the silver contacts on the adapter, should lit green. If it's not lit, make sure the power cord is properly secured in it. Otherwise, you're looking at a defective power adapter. If that's the case, I suggest you contact Lexmark Technical Support and request for a new power adapter for your printer. They can send you one for free. If it's lit, plug it back in the printer in the right position. If it won't automatically power on, press the Power button. If that doesn't help, the problem might be on the printer itself. Again, if that's the case, I suggest you contact Lexmark Technical Support. Hope this helps.
Jun 23, 2010 | Lexmark X3650 Printer
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
I put a new black printer cartridge in and now it doesn't power up at all. I replaced the printer cartridge with the old printer cartridge and it still isn't powering up. I replaced the power cord,...
With the green light lit on the power box or power supply of the printer, that indicates that there is power flowing. But just to make sure it's getting enough to power the printer on, bypass any power strips or extensions, if you're using one, and plug the power cord straight to a known working power outlet. Make sure the power box or the power supply is inserted all the way in the slot and in the correct position behind the printer. Press the power button if needed. Hope this helps. If it's still not powering on, I suggest you contact Lexmark Technical Support for further assistance.
May 04, 2010 | Lexmark X4690 Wireless InkJet Printer
I have a 2 yr. old C6180. It will not turn on as of yesterday. Power is coming from the socket as the little green lights on the plug are lighted. I have unplugged all cords and plugged them back in but...
try unplugging power cord and holding #6while your plugginmg in the power cord hold the button down until you see the display lights turning on and release if you are printing wirelessly you will have to do the wireless setup wizard again.
if that doesn't work try plugging it directly to the wall
if all else fails it may be the printer
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Kodak esp 5 printer wont turn on
Make sure that you have green light on the power cable, which goes to the back of the printer. if it is not lit up,the power cord is bad.If you have light there and the printer is still not turning on,make sure that the power cable is inserted properly to the back of the printer. is still issue is not resolved, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost.
Mar 23, 2009 | Kodak ESP 5 Printer
139 people viewed this question
Seeker5211
Seeker5211
