Question about Toyota SL3487 Sewing Machine
I'm looking for instructions on how to thread a serger. It's a Toyota model about 12-14 years old. The guide is on the machine and much to small for me to see it. Is there an instruction manual out there to guide me through the process? Jan Carlson e-mail j-jcarl1@comcast.net
  • 340 Answers
I found the manual and on line threading guides for my Toyota on the Aisin French site.
Here's a copy of the manual.
http://www.aisin.fr/catalog/download//manuel%20SL1,%20SL1T,%20SL1T-X,%20SL1A.pdf
Their online guide for threading a serger is only available in French, but it does have good coloured diagrams that you can enlarge.
http://www.aisin.fr/catalog/download//SLEnfilage.pdf
They also have spare parts and accessories for this machine. I've found it a really useful site.
http://www.aisin.fr/-c-53_41.html?page=1&sort=3a
Hope this helps!
Posted on Oct 01, 2010
Testimonial: "Came upon your website kind of by chance,and found it very helpful. Will probably call upon you in the future. "
  • j_jcaral1 Oct 01, 2010
    These instructions were a huge help. Haven't tried them yet, but all the diagrams are exactly what I'm looking for and muost of the instructions are also in English. Thanks for all your help !!
  • lamel8 Jul 30, 2011
    My sister needs the manual for the Toyota Overlock Serger Model 5500, I found this site, but the resources have expired. Please help. contact me at lamel8@aol.com
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
How do I get my Serger to sew properly?
I'm afraid you've threaded your serger incorrectly. I've done it myself more than once, so I try to make sure that I tie new thread to old and pull it through the machine rather than try to re-thread it. That avoids the problem for the future, but doesn't help you now.
Here's what you can do right now to work out the problem:
1. Get out your owner's manual and check the thread path(s) for each thread. Be sure you've got them right, especially the loopers (usually the two threads on the right-hand as you look at the machine).
2. If you don't find any obvious errors, change the sequence of the looper threads - that is, which one is threaded first. I know it doesn't sound like this will help, but it fixed mine.
3. Be sure that none of the threads are caught under the feed dogs, they should pull fairly freely toward the back of the machine.
4. Start sewing without fabric in the machine. I know this is wrong for a standard sewing machine, but you should get a 'chain' with a serger. If it's not 'chaining,' go back and try these steps again.
5. If that doesn't fix the problem, or if it chains and still won't stitch, change your needles. They should be changed now and then anyway.
6. Be sure to lubricate your machine often according to the owner's manual. Most sewing machines need more oil than they get.
Apr 08, 2015 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Cant thread correctly
Do you have a manual?
You can get a free manual to download for a Toyota Serger here:
They also have a threading guide, in colour, but it's written in French.
Although the manual is for another model number, it should be useful as most sergers thread in exactly the same way.
Hope this helps!
Nov 22, 2010 | Toyota TL-432DE Mechanical Sewing Machine
Hi, I am looking for a manual for a toyota Serger model #6700. Any help is appreciated. Thanks
http://pages.sewing-machine-manuals.com/173/PictPage/3923511099.html
I found this site and they have printed copies of this manual. I have not ordered it yet still looking for my original, but may have to soon. Hope this helps.
Nov 09, 2010 | Toyota Sewing Machines
Don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
Mar 12, 2010 | Juki MO-735 Mechanical Sewing Machine
Threading rl-635 serger--wife is trying to tread this machine and the lower something or other doesn't work. Cannot find a manual, and the tape they sent with the machine is all messed up.
Sergers can be a bear! One miscue and - well you know. My old serger was threatened more than once.
Are the instructions for this model printed on the inside of the door or on the machine?
Note every guide and make sure none are missed.
Raise the thread antenna to it's highest position.
Raise the presser foot and turn the tensions to zero.
Start threading with the upper looper, making sure the loopers are not crossed.
The upper looper is the one that appears to be taking the thread toward the needles.
Make sure the threads do not cross as you then thread the lower looper (this one appears to be taking the thread away from the needles).
Lastly - thread the needles; right needle first.
Take the ends of the thread under the presser foot and toward the left side of the presser foot.
Lower the presser foot and set the tensions back to 3 - 6.
Stitch a chain of thread before stitching fabric.
If this works, and I sincerely hope it does, never let the serger run out of thread.
Snip the thread near the cone and tie off snugly with the new thread.
Lift the presser foot and open the tensions and stitch or gently pull the thread toward the back of the serger. The knots should clear all but the eye of the needles - stop, cut before the knot reaches the eyes
Feb 22, 2010 | Riccar Sewing Machines
Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Jul 18, 2009 | Sewing Machines
Threading illustrations too small
You might take a look on ebay item 160362974035
May 29, 2009 | Baby Lock Eclipse Serger
Don't know how to use Janome serger 1110de
The order of threading is most important. If you letter the tension knobs from left to right A,B,C,and D. The order for threading it is C,D, B, A. There are two arms under the needle that cross each other called loopers. The order is upper looper, lower looper, right needle, left needle .I'm sure there is a diagram under the cover when you open it. Most do. It would be very helpfull to use a long threading tweezers to guide the thread through the holes. The lower looper has a hole in the back to put the thread through then through the front hole ( though some newer sergers have a lever that you put the thread on and it does it for you and over the thread of the upper looper and out the back.
It would help alot more if I knew the brand and model of your serger so these are basic instructions. Hope I helped.
Rick
Feb 12, 2009 | Janome Sewing Machines
Toyota SL3487 Sewing Machine Logo
413 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
