Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have tested the valve and it's is opening and closing but the icemaker keeps putting power on the valve everytime it cycles and never stops. The valve is shutting off water each time. What in the icemaker is making this do this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Yes, every time the icemaker cycles, it will switch in power to the icemaker water valve. the icemaker is pretty much a standalone device. All it needs is power and water supply, and valve. If it has both, and is not working properly, then the icemaker is bad.
Posted on Oct 01, 2010
    Sergeant:
    Champion:
  • 351 Answers
Harvest thermostat
  • 2 more comments
  • Russell Trella Oct 01, 2010
    What does the harvest thermostat do? There is a screw for adjustment for /-. I turned it up and it's holds the solenoid in longer. I'm going to turn it way down and the water should freeze and play with the adjustment to get it not to over flow. W
    What does the harvest thermostat do? There is a screw for adjustment for /-. I turned it up and it's holds the solenoid in longer. I'm going to turn it way down and the water should freeze and play with the adjustment to get it not to over flow. The adjustment turned down only puts alittle water in at a time. Do you think the adjustment was off. I think this started after a filter change and maybe got to much flow.
  • sparks194520 Oct 04, 2010
    the best thing to do is to replace ice maker
    the screw is for cube size i would replace icemaker
I have an older fridge with the ice maker in the freezer, just dumps into tray below. Anywho, water leaks from the ice make everytime it fills into the pan below, making one giant junk of ice. Please...
you have to determine if its the icemaker mold that has a crack and therefore leaks, or if you water valve solenoid is not closing compeletly at the end of the cycle. to check this, turn the water supply off to the refrigerator, then lift the arm up to turn the icemaker off. wait 3-6 hours, in case it JUST cycled, turn the icemaker back on, and it should dump one last set of ice cubes. slowly pour 4-8 oz of water into the icemaker with a measuring cup. do you see that same drip? if you do, replace your icemaker, if you dont, replace your water valve.
Mar 17, 2010 | Refrigerators
No water to icemaker. Water in door works well.
the water that enters the ice maker is controled by a thing called a solenoid valve (electricaly operated) the" water in door system" is a manual operated valve.. typicaly when the ejector rolls around to put the ice in the tray the solenoid opens lets water in then closes could be solenoid / wireing or controler
good luck
Oct 23, 2009 | Kenmore 57029 Side by Side Refrigerator
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Ice maker overflows water during the water fill cycle
is the icemaker level side to side front to back if yes how is the water flow at the disp is it slow? then have you changed the filter in the frig ? No filter and water is still slow coming out follow the waterline from behind the frig follow it to where it hooks up if a saddle valve shut it off all the way use a hand towel to increase tork while shutting down then open it all the way open test the water at the disp again do you have better water flow coming out then the imkr may stop leaking the reason you are checking and testing the above is if you do not have at least 35psi of water pressure the valve will not close fully and overflow the icemaker another test is when you get water from the disp does the water shut down when released or does it continue to run/drip if so the water psi is the cause although useful not always as reliable
Sep 09, 2009 | Whirlpool Refrigerators
Have a bi95 water not going throught inlet valve,hose is clear to freezing tray. took valve apart did not see any obstruction. any suggestions? thanks mike55
The valve assembly for U-lines shouldnt be taken apart. Now the first thing is to advance the icemaker. Remove the cover off the icemaker head. (pry and pull at the same time) use a 5/16 nutdriver or socket on the small gear. Turn it counter clockwise. Whent he ejector blade reaches 1 or 2 oclock it should take off by itself. When the ejector blade reaches 10 oclock then it calls for water.
(ejector blade is the fingers that push the ice out)
How a bi 95 works is the thermostat need to be satisfied first. Then it advances the icemaker. Turn it to the warmest setting. If its set too cold then it would run and never be satisfied.(warmer the setting the more ice it makes) Everytime the compressor cycles off the icemaker should be advancing. If not then the thermostat could be stuck in the freeze mode.
T-stat Terminals 2 is yellow(common)
3 is blue/black (fan & compressor)
1 is red (icemaker)
2&3 closed freeze cycle
2&1 closed harvest mode
Jul 10, 2009 | U-Line Icemaker
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
My whirpool side by side refrigerator/freezer won't make ice- what could be the problem
Mar 31, 2008 | Refrigerators
Ice Maker
Pop the front cover from the icemaker
Use and insulated wire with about 1/2" of bare wire exposed on the ends to jump between the T and H holes in the module.
This will start a cycle. Remove the wires after 5 seconds and let the icemaker run it's cycle.
Listen for the water valve to open. It should open for about 7 seconds just before the end of the cycle.
If it does not open, jump between the L and V holes in the module.
This puts power to the water valve, bypassing the switches in the I/M.
If you still have no water and the fill tube from the valve to the icemaker is not frozen, then you probably need a valve.
If you have a volt/ohm meter, you can check it a little more precise by checking for voltage to the valve while the icemaker cycles.
Post back if you have questions.
Thanks/Mike
Dec 02, 2007 | Refrigerators
Amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
413 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
