Question about Philips Magnavox MRD500VR System
I get protect audio off when I turn it on - Philips Magnavox MRD500VR System
    Genius:
  • 1,622 Answers
Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
Take care.....
Posted on Oct 01, 2010
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
How do you reset the protection mode
The protection function has been activated because it has sensed an output load problem, turn receiver off and remove the speaker wires, this will reset the protection circuit. Now! turn the device on and turn the volume right down, if the protection mode stays off it indicates a short in the speaker wire or one of the speakers, but! if the protection circuit comes on with "the speakers and wires dis-connected" it means there is a short in the audio outputs in the receiver itself, this can only be rectified by having the parts replaced.
Mar 02, 2011 | Sony STR-DE585 Receiver
Radio flashes (protect)cant get any stations at all
This is an indicator of an output load problem, turn unit off! remove the speaker wires from the back of the stereo, now turn power on and turn the volume down. If the word protect stays off there is a short in the wire or one of the speakers, but! if the word protect comes on " with the speakers and wires dis-connected " it indicates a short in the audio output ic pack in the stereo.
Feb 23, 2011 | Kenwood Audio Players & Recorders
I was playing some music pretty loud today on my Sony STR-DB790 and then no bang no crackling just strait to protect mode turned stereo off thinking nothing of it and now every time I turn it on strait to...
There is an output load causing the protect to engage, turn unit off and dis-connect the speaker wires from the back of the receiver, this will reset the processor ic. Now power on and turn volume right down, if the word protect stays off it means there is a short in the wires or one or more of the speakers. But if the word protect comes on with the "speakers and wires dis-connected" it indicates a short in one or more audio output ic's and will need a tech to address the extent of damage and cost.
Feb 06, 2011 | Sony STR-DB790 Receiver
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect light will not turn off!?
In most cases when the protect light is lit, the amplifier's output transistors have failed.
If the amplifier goes into protect with no speaker wires connected to it, it's likely in need of repair.
Nov 26, 2007 | Kole audio QX1-2400D Car Audio Amplifier
Philips Magnavox MRD500VR System Logo
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
