Question about KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher
Model kudk031tbt3 I need to replace cover latch it pops out of the door during wash the dipenser door does open during wash. How would I replace latch
2 Suggested Answers
SOURCE: KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
Posted on Sep 18, 2011
Rear hatch door will not open
This is a tough one some of the older models had a small plastic round cover at the bottom inside, you remove the cover to gain acces to lever to pop open door, other wise you will have to remove the door panel from the inside to get to latch,
Jan 23, 2013 | 1999 Plymouth Grand Voyager
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
May 27, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Washer door wont latch ghw9200lw duet
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Door popped open during the wash cycle and now will not close
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2009 | Kenmore Washing Machines
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Open Questions:
KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher Logo
78 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
