Question about LG 62SX4D 62" Television
My lg 62sx4d-ub will not turn on. You push the power button, the ballast clicks, then the leds begin scrolling white. Eventually the lamp led flashes red and it shuts back down. I've changed the bulb already, that didn't help. Ballast? Power Supply?
I just had the same problem. Came down to a bad cap on the main power supply board C871. This is the first filter cap after the diode on the 6V supply. Funny,, the schematic calls for a 25V part,, however this one was rated at 16V :-)
Replaced with a new one,,, all is good to go!
Jer in Hayden
Posted on Oct 26, 2010
  • 3 more comments
  • Jonny Boy84 Oct 28, 2010
    Jerlong, I am having the same issues. How did you check the C871? Mine seems to be testing okay, yet the transitor D871 has dead shorts with the OHM meter.
  • Jerlong Oct 28, 2010
    Jonny Boy84, I do not have a capacitance meter,,, so I just replaced it. The symptoms were pointing to this cap,,, so therefore the change. As far as your transistor,, if it is a true bipolar transistor, it looks like you have found your culprit (if it actually checks bad out of circuit). Some FET transistor measure shorted though (depletion mode FETS) so be wise.
    Jer
  • Jonny Boy84 Oct 29, 2010
    Jer- C871 was bad. Replaced now everything is good to go!
  • db554 Feb 08, 2011
    how did you change this part and where do you purchase it? Thanks for any help.
  • Jerlong Feb 09, 2011
    Soldering iron to de-solder with solder ******. New one I found in a failed computer power supply :-) You can buy new ones though, I would imagine that Radio Shack would have one that would work. Just be sure the voltage rating is at least 50% more than the supply voltage.
NO LED indicator for power, fan on, Lamp does not turn on, Lamp LED
The ballast board controls the lamp operation. Your problem lies there.
Nov 04, 2013 | Epson EMP 730 Multimedia Projector
White LED scrolling then click and then the top two LED lights turn red with the first one constantly on and the second one flashing.hey guys we were given a rear projector tv by family friends and they...
You possibly have a lamp issue but most of the cases like that,,
The capacitor is leak or bulged on top..You have to replace it to fix the problem
Nov 08, 2012 | LG 62SX4D 62" Television
Sony KDF-E50A10 Power Up Problem with Display
yes it possibly lamp ballast board is faulty
Oct 13, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Front LED just Cycles white then goes red. Replaced lamp did not fix set. Found 5 volt power on command missing from Digital bd to DMD bd. Need to replace Digital main bd. Part needed is 6871VSMS28B. Will...
Good day!!!
if the command signal from main board to DMD board missing the problem could be the main board..
I already found the board online for only $75 on this site http://www.discounttvparts.com/6871VSMS28B_p/td-1169.htm
$100 on this site http://www.ebay.com/itm/NEW-LG-MAIN-UNIT-6871VSMS28B-6870VS2273C-/260877125964
Hope it helps..
just add a comment for any follow up questions..
Thank you
Jan 26, 2012 | LG 62SX4D 62" Television
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Missing a color on a LG DLP 62SX4D-ub
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | LG 62SX4D 62" Television
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
LG 62SX4D 62" Television Logo
1,397 people viewed this question
Computer Repairing
Computer Repairing
