Question about Frigidaire GLTF2940ES Front Load Washer
Washer does not spin at high speed - Frigidaire GLTF2940ES Front Load Washer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
The washer will not spin if it doesn't drain properly. Verify drainage. Also, the latch assemly goes bad on these all the time.
Posted on Oct 01, 2010
mikedurland
  • 481 Answers
SOURCE: Whirpool Ultimate Care II washer Imperial Series spins at low speed
Posted on Aug 12, 2008
  • 30 Answers
SOURCE: frigidaire front load washer will not spin
Two possible reasons the lid switch may be defective, or the spin bearing may be worn.
Posted on Sep 03, 2008
  • 63 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
Posted on Nov 12, 2008
Jeff the TV
  • 82 Answers
SOURCE: my TROMM washer only spins on extra high speed
This washer will automatically choose the fast spin, you can do only spin, don't make the first selection "soil level", just press the spin speed then start.
Is the problem that it is noisy and shaking?
try to level the feet. The installers should have given you a wrench to accomplish that.
Posted on Jul 25, 2009
  • 142 Answers
SOURCE: Washer will not spin at high speed
check for any blockages around pump and air trap area.
Posted on Sep 14, 2009
My Frigidaire front load washing machine has stopped high-speed spinning. The regular spin works but not the high spin. Any ideas how to fix that?
Hello Mike, thank you for your post!
From what you have described your Frigidaire washer is not spinning on a high speed. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician out to perform a proper diagnosis and repair on your washer. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Apr 29, 2015 | Frigidaire Washing Machines
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
Feb 05, 2011 | Washing Machines
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22622 will not shift into high speed during spin cycle leaving clothes very wet every now and then it will go to high speed. i tried turning the dial around a couple of times and it went into high...
Possible overloading or a situation many people do not consider is underloading ,if your machine has an out of balance sensor this will operate in either event and hold the spin to protect your machine .
Nov 03, 2009 | Kenmore 22622 Top Load Washer
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
My TROMM washer only spins on extra high speed
Jul 25, 2009 | LG WM-2277HW Front Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
