Question about Maytag Neptune MAH5500B Front Load Washer
Door does not open , when unplug, turned off, door does not open
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Look in the dispenser for a green nylon cord - looks like weedeater line. I believe it's green but can be another color. Pull it. This is the emergence release and will allow you to get your clothes out. Chances are you have a bad wax motor and control board. Check control board for burned resistor. Your looking at a 3-400 fix. Otherwise, look on ebay. You can buy a kit for cheap and do the repair yourself if you know how to solder.
Posted on Oct 01, 2010
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
Mar 29, 2012 | Frigidaire Dryers
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
MY ICE MAKER MAKES ICE BUT FREEZES UP AND TRHEN I CAN'T GET ICE OUT. I TRIED TO OPEN UP THE FREEZER COMPARTMENT BUT I CAN'T GET THE COMPARTMENT DOOR OPEN. HOW DO I GET THE ICE MAKER DOOR OPEN. I...
Unplugged, Then allow 1 or up to 5 hour then open, if not get screw to open the compartment door. check all side of the compartment door. avoid so much full content to your ice maker refrigerator, and always give a free space to the compartment door.
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
It keeps on sayin my access door is open but my printer doesnt have a rear door
Access door is usually the one that opens to allow the insertion of new cartridges. Try opening and closing that one and restarting the device after completely unplugging from the mains and waiting 30 secs.
Please rate this answer!!
Cheers
Bob
Jan 09, 2011 | Office Equipment & Supplies
My front loader door is locked and will not open, I have tried to restart, unplug and everything the machine is turned off and the door still will not open.
First unplug the washer. Remove the front valance under the door (three screws at bottom front of machine) reach up inside by the door lock area and there will be a plastic tab, pull that tab down and that should unlock the door.
Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Auto headlight feaature not working
Before you go into any extensive electric workup, you should first check the trigger on the door to see if it is defective. It happens often in ice cold weather on old vehicles. It is a little black mushroom held by spring on the frame where the door has contact with. Wiggle it a few times to see if it turns the lights off.
Feb 03, 2009 | 1995 Toyota Camry
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
