Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
A husqvarna yth21k46 kohler 21hp hydrostatic,5 minutes on it, when cranking it has a clanking noise won't start
  • 1 more comment
  • rbitc43 Oct 01, 2010
    you can see the top of the engine spinning is that the fly wheel?
  • rbitc43 Oct 02, 2010
    sheila I got it to run by taking out the electronic selenoid? that is screwed into the bottom of the carb that I beleive operates the float and I held my finger over the hole tightly, and it keeps running, I tested the part with a battery and it does retract, I used a multitester on the wire feeding the selenoid and it gets 12 volts, when I put it together turn the key on you can hear the selenoid retract, a small clicking noise, the tractor will sometimes run for a second or 2 but thats it, so either the selenoid is not working properly or its something else?
    I bought the tractor at lowes cheap because it wouldn't run. I learned that the gas smelled like varnish so I cleaned the tank flushed the fuel lines, carb, but It only runs if I take the selenoid? off the bottom of the carb hold my finger over the hole and, I put the selenoid back on it won't run but for a second or 2 , I tested the selenoid? with a battery it does retract like it supposed to, I tested the wire supplying the selenoid it gets 12 volts, so its either not working exactly like it should, or what regulates it isn't working right, I think the knocking noise was because of not starting and properly lubing, because when I did have it running it sounded good. thank you ps tomorrow I'm going to replace the selenoid? on the carb and take it from there.
  • 734 Answers
Don't ever crank it again. They forget to connect something at the factory. Do any more, and they'll fight you not to fix it. Now, call them and make them fix it.
Posted on Oct 02, 2010
  • 3,083 Answers
If this machine only has 5 minutes on it, and is having this kind of problem, my advise would be to take it back pronto and get a replacement or another unit. Whatever this noise is, it isn't ever good, and can be expensive to fix by the time you hear it.
Does the mower have oil? Is anything else engaged when the motor is cranked? Never owned one of these, so I'm not sure of their operation.
If your warranty is still in effect, I would take it back. Whatever this noise is, it can't be a good thing.
Posted on Oct 01, 2010
  • 2,973 Answers
There is something known as BENDEX on the starter motor. If this goes bad then you hear the clanking sound and the starter pinion does not engage the flywheel. Sometimes it does engage and the machine starts. It can be repaired if the fault is minor or it has to be replaced if fault otherwise. This can be ascertained only after opening it.
Where is the sparkplug located on a YTH21K46?
It would be located screwed into the cylinder head of the engine.
Jan 21, 2015 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
Parts manual for a yth21k46
Type: Husqvarna YTH21K46 into google where you will find the manual in .pdf and a complete parts list.
Jul 13, 2014 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Engine cranks but does not start on 21 hp briggs and straton
May have oil in the carb. If it smoked its burning oil due to having to much in it.
Jul 02, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Engine starts when clutch is depressed but stalls when the clutch(brake) is released>
Start with a simple thing first, make sure the connection block to the seat micro switch is pushed completley on, if it moves back even a few millimeters you will get this problem, if this does not work check/replace the seat switch, if no better it could be one of the relays situated under the bonnet by the side of the fuel tank, they look like 2" square black boxes, they will just pull of the connector block with 5 or six pins.
Oct 09, 2012 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
How can I get an operation/service manual for a: Husqvarna 21-HP Hydrostatic 46" mower
Your best bet would be to go to your local dealer. They can get you what you need, answer any of your questions, or supply you with parts you may need for your machine. GOOD LUCK.
Jul 08, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
392 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
