Question about RCA Televison & Video
Rca fuse keeps blowing in 1991 home theater television f35100st
shaggyrat
  • 1224 Answers
SOURCE: E.E.C fuse keeps blowing in 1991 Ford Explorer
if you replaced fuel pump i would look at backward wiring when replaced and i would start at the source of work if your vehicle was working fine before replacement then 9 out of 10 it will be your fuel pump wireing
sometimes when putting wireing back together the connectors have the missing clip and in turn you can turn the wireing in both directions now where positive is touching the ground on both sides of connector kris kross problem check your work this is crucial use a test light to find the right wires where they go
Posted on May 26, 2008
  • 40 Answers
SOURCE: rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Posted on Jul 25, 2008
  • 6 Answers
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
Posted on Dec 13, 2008
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
Murphybanton
  • 2004 Answers
SOURCE: Gauge fuse keep blowing up
7.5A fuse keeps blowing because there is an electrical connection fault. Take the car for diagnosis.
Posted on Mar 19, 2009
Where are fuses located and how to tell if one is blown
Fuses are usually inside on the circuit board. A blown fuse is usually burnt, so it will be visible. If you are not sure, you can remove it at hold it up to a light. You should see a small wire inside the fuse. If it is blown, you will see a break in the wire. Keep in mind, a blown fuse indicates something is wrong. If it blows again, have it tested by a electronic technician.
Feb 04, 2016 | RCA RTD317W, DVD Home Theater System with...
Lost all power in 1991 RCA TV model F35100ST
Best thing to start here is open up the TV and look for any blown components on the power board (which is the one that has the power cable attached to); check the transformer for continuity first, that is the first thing to blow. Then go on with capacitors, resisters, and any burnt wires.
All of these parts are easy to find and replace, they can be found in local electronics shops.
Please post back how it went and any further information or questions you may have, so we can help you better.
Dec 14, 2007 | Televison & Video
RCA RTD315 Theatre System- When I turn the main unit on, it comes on but shuts itself off after less than a minute????????? Any ideas what's happening? Can I purchase just the receiver anywhere. Have had...
Look like the board over heating. Please check working condition the fan. Keep far the player from wall or items that can possible close blow out of the fan. Also available home theater units avsystemparts.com
Oct 03, 2013 | RCA RTD315 Theater System
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
Blowed up in my RCA RT 2770 a resister and I need the number
Contact customer service, http://www.1800customersupport.com/rca
Feb 22, 2010 | RCA RT2770 Theater System
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
The screen just shows a single line in the center from top to bot
vertical deflection failure. either solder on vertical ic, or bad capacitors in vertical circuit, and bad resistor &or ic failure. we fix these in home for 150.00 including 1-year warranty and trip. (oh plus tax for the next stimulus) mch
Mar 08, 2009 | RCA 36F530T 36" TV
Where can we get SB fuses?
SB stands for slow blow. If a fuse is the right size physically and the same amp and voltage rating, a slow blow or time delay fuse is the same, no matter what the markings.
Feb 10, 2009 | RCA RT2300 System
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
Televison & Video Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
