Question about Sony Cyber-shot DSC-W55 Digital Camera
I have a 2001 sony digital8 handycam and it will not playback anything on my tapes even if i just recorded something or someone, and i have tried new tapes. No matter what it will not play back anything and i dont have anything else, or know any other way to watch my old family movies.
  • 153 Answers
Have you tried using a cleaning tape? It may be the heads are dirty.
If not it may need a service, even if its unserviceable due to age they go fairly cheaply on ebay, and it may be wise to pick up a spare anyway.
But regardless with the age of digital8 and 8mm in general i would recommend backing up your tapes.
DVD recorders can now be bought very cheaply, If you buy a fairly good one (I have Liteon LVW-5006) It should have fire wire / DV link so you can transfer your pictures digitally you can then fairly easily edit your videos with something like "womble" on your PC
Don't forget to copy your disks every 5 years (or less depends how precious the films are and keep duplicates) and keep them well out of sunlight as DVD's quite often fail quite quickly, leaving one in the sun can kill it in hours.
Posted on May 26, 2008
When I press record a tape with a line through it appears and also and arrow with a line under it.. and it makes a beeping sound and blinks.. Please help
Make sure that you are using a Digital8 tape. There were 3 types of 8mm tapes made...Digital8, Hi8, and plain 8mm. This camcorder will only record on the Digital8 tape. There is a a tab on every tape that makes it impossible to record over. Check to see if that is in the wrong position. Also, check to make sure that you are not at the end of the tape. If none of the above has helped so far, there are a couple more things you can try yourself. You might try a different tape or run a Sony head cleaning tape for about 5 to 10 seconds. If you have tried all of this and still no luck, it is maybe time to take it to to an experienced technician for repair.
Hope this helps you.
Aug 04, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Recording and playing a new tape worked for me too. Thanks!
Mar 17, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Sep 13, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony Cyber-shot  DSC-W55 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
