Question about Dishwashers
My dishwasher appears to have a filling problem. Is there a way to fix this? Thanks.
  • 4,340 Answers
Yes, there is, you find out that the issue is and fix it. Commonly, there is a plugged inlet screen at the water valve. Verify that you acutally can get water to that point.
Posted on Oct 01, 2010
Dishwasher comes on and goes though all the cycles but no water! Is it a easy fix and inexpensive fix or do i need to think about a new one. Thanks for any help you maybe able to give me.
Two things to check, first make sure the water is on to the dishwasher itself. Second, if
the fill solenoid (12 to 28 dollars usually) has failed, the dishwasher will not fill. It is
a fairly simple fix and can be done with the dishwasher in place. Just make sure power
is off and water is off when changing out. Model and serial are usually inside the door of the
unit.
Hope this helps.
Jun 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Apr 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Samsung DMR57 Dishwasher gives me error code 9e, telling me its a low water level error. Anyone know what this is and how to fix it ?
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Aug 17, 2009 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
We have gravity water feed and is not filling up quick enough. Could i mix with hot water as well.So putting in a y to mix cold and hot together. Thanks Dave Williams
hi dave. actually you are supposed to fill a dishwasher with hot water only.
the long term fix for your gravity feed water system would be a shallow well pump.
please rate my answer as a fixya ,thanks
Feb 18, 2009 | Hoover HD95M Free-standing Dishwasher
Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Dec 29, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
