Question about Whirlpool Washer Timer Knob Part Number 356500
Sm8525492-a will not advance to next cycle - Whirlpool Washer Timer Knob Part Number 356500
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
My whirlpool washer sm8525492 will not spin or agitate
your lid safety switch is bad,remove the control panel,set it back,then remove 2 brass colored spring clips from top cover behind the lid,tilt entire cabinet toward you and remove,lid switch can now be replaced from under the cabinet that you removed
Dec 22, 2010 | Washing Machines
Can you direct me to a user guide? I've moved to
The advance button send the current program to the next state. So if you have 3 on - off cycles programmed per day and you are currently at the second on cycle then by pressing advance the program moves to the second off part of the cycle and will stay off until the next on command time is reached. So if you are on Heating the advance will only affect the heating. Similarly if you are on Water then it will only advance the water program.
Sep 29, 2009 | Hardware & Accessories
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer fills with water but does not advance to next cycle
If this is a rotary timer, nudge the timer slightly in it's normal direction of rotation. If the timer keeps going (it might hang up at the next point in the cycle, but nudge it again), I suspect the timer needs to be replaced. They get weak.
Jan 29, 2009 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Whirlpool Washer Timer Knob Part Number 356500 Logo
338 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
