HP Compaq Evo Notebook N600c Logo
Posted on May 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compaq EvoN600c My laptop screen does not stay upright. It needs to be held/propped up or it will fall back and lay flat. Any suggestions would be greatly appreciated!
Anonymous
Level 3:
Genius:
  • Master 1,027 Answers
  • Posted on May 26, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1027
Questions
0
Helped
641806
Points
2823
Sounds like time to replace the hinges. check e-bay, there cheap
2.99 + ship
What is the proper way to move the fridge?propped up or lay it down?
For tranporting you must keep it upright. If you have to tilt or lay down be sure to let stand uprigtht off for 24 hours before turning back on.
2answers
I have a Compaq Armada M700 and the top part the display screen falls back - it no longer stays upright or at an angle.
on the m700 i think you can tighten the hinge........
if not i could always send you hinges......
cheers
I have a Sony Wega KP-FX432M91 Prjection TV. I am moving house and I want to know if I can lay the TV flat on it's back to move as it's too tall to stand upright in our vehicle
Please do not lay tv on its back because of its internal design, things are mounted inside vertically and screws are holding them in place. Laying tv on back will put force on screws that might came off or get loose and you will end up with a distorted picture on tv screen.
Move tv in stand upright position, it is safe.
Hope this will help.
Thanks.
3helpful
3answers
The 261380-001 HD for my EvoN600c is dying. Can I upgrade to a larger capacity drive as long as I stay within the 2.5"/9.5mm size? Can I go to 100 gb?
As far as I am aware you can use a 640Gb drive if you can get one but that is a little too large!
120Gb should be fine.
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
I wish to move my Panasonic Vieta to another address.
I would wrap a thick cloth towel, blanket or comforter around the screen and lay it face down (screen down) on a flat surface, making sure the TV will non move in any way. If you transport it face up, there may be a chance that something may fall on the screen and damage it.
Frozen screen
its probably just to hot thats why my friends play it upright helps cool it off but in your case i suggest buying a cooler for it.
2helpful
Screen won't stay up
Sounds like the screen hinges are worn out and need to be replaced.Get some new hinges and put them in.That will fix your falling screen problem.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
