Question about Bosch Tassimo TAS4511UC Coffee Maker
My red heating light stays on all the time - Bosch Tassimo TAS4511UC Coffee Maker
Dualit Toaster on light blinks
Most of the time it is indicating something is wrong. What? could be a thermostat, an overheating sensor, bad cabling inside, or just the element.
Mar 10, 2015 | Dualit Kitchen Appliances - Others
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Red protection light stays on all time....
try disconnecting one at a time each speaker till the red turns to green. One of your speakers may be bad. Amp is just telling you that its clipping and overheating due to the change in ohms of a shorted or bad speaker. Its also possible the amp is on its last leg due to heat. Heat breaks down electronics part and eventually get worse.
Apr 05, 2010 | Car Audio & Video
Red and Green lights both stay on AW1200 and now
The temperature in my office was 38 degrees yesterday. After I turned the heat up the printer "dethawed" and started working normally. I believe the problem was environmentally induced and therefore solved with the more moderate temperature. Thank you for your reply.
Jan 03, 2010 | Xante AW 1200 Laser Printer
Stays on red light and beeps
Yes this is the YLOD (Yellow light of death) you need to stop the heat build up, you can do this yourself or you can sned it in to get it fixed.
Dec 30, 2009 | Sony PlayStation® 3 (60 GB) Console
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Ps3 problem, ps3 doesnt turn on (stays in red light flashing)
Sounds like a heat sync problem. you will more that likely need to re-seat the GPU and CPU as well. email dwdpcrepair@gmail.com for more assistance
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
Cooling light stays on
If you are referring to the blue temp light on the dash, it stays on until the engine has reached operating temperature. This lets you know the heat will be ineffective and the engine will not be running at peak efficiency during this time.
May 15, 2008 | 2004 Scion xB
Bosch Tassimo TAS4511UC Coffee Maker Logo
5,063 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
