Question about Terapin TX-0002 CD-R Burner
Hello anytime i put a disc it says no disc - Terapin TX-0002 CD-R Burner
  • temidayo shoneyin Oct 01, 2010
    Thanks I think those suggestions cover everything i need.
  • 857 Answers
Follow these steps to fix your problem :
•1
Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the DVD player's ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
•2
Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn't support home-burned DVD-R's, then you can't use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
•3
Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
•4
Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
•5
Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
•6
Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
Posted on Oct 01, 2010
Disk error
Sony handy cam dcr-sr20 HDD format ERR 31:00
Apr 30, 2013 | Sony Handycam DCR-DVD201 DVD Camcorder
How to unlock forgotten password of the mobile memory card?
there's a tool in the market do that , its work with battery 9V or usb connector.
just put the memory in Hub and insert the Hub in that unlock tool and run it ..
Apr 24, 2011 | Nokia Classic 2700 Cell Phone
My xbox 360 clicks twice whenever I put a disc in or try to play a game.
That is a sign that your laser is dying. Make sure to buy a new laser or a new XBOX CD DRIVE as this can fail at anytime.
Apr 12, 2011 | Microsoft Xbox 360 Console
Hello, my LG Bluray player has audio sync problems when I hook up a USB device to play a movie, but works fine with Bluray and Dvd discs. LG BD560C.
This is an known issue for LG streaming video from USB devices, it also happens to LG HDTV's for unknown reasons. No permanent fix yet but normally rewinding the movie and fast forwarding again to the same spot fixes it but not permanently as it might re-occur anytime.l
Apr 08, 2011 | LG Televison & Video
I want to do a restore to factory default
That disc is the OS disc. The anytime upgrade is offered by the manufacturer but is a Microsoft Windows issue. There were two types of upgrades. One let you roll back a Vista machine to XP; the other lets you switch to a higher version of the OS (Vista comes in several flavors - Home Basic, Home Premium, Business, and Ultimate). Look at microsoft.com for details.
I'm not surprise that they wanted money to help you. The company makes money on support.
If you want to, you can use the OS disc to do a clean (custom) reinstall. Boot from the OS disc and then reformat the hard disc during the installation. Get the drivers from http://www.emachines.com/support/drivers.html and fill in the drop downs. Have these handy because you will need them.
I hope this helps.
May 15, 2010 | E-Machines eMachines Desktop PC
Dent in center of game disc
If you paid money for an extra service, I think you should take advantage of that service you purchased. The disc might run smoothly as of now, but might fail anytime soon due to this dent you are claiming. Considering that the Xbox 360 Console is very sensitive and you can really never tell what's gonna happen. So , it'll bebetter to have it replaced from the store where you got it. :)
May 11, 2010 | Video Game Consoles & Games
Anytime i put on the phone it gives me this message. initial programing required.i cant switch from cdma to gsm. i need help with the subsidy lock code.
Hello my friend.Simply reboot the phone!To do this push the reset button on the bottom of the phone with the pen or pull the battery out and put it back in.
Feb 09, 2010 | Motorola Cell Phones
I have an iBook G4 and for some reason, no matter what brand of blank CD I put in, it won't show on the desktop OR in a separate finder window. iTunes comes up... but I don't want to burn a music CD...I...
Hello there, both questions can actually be answered at the same time - at one point, it seems the autoplay menu that normally pops up when you pop a blank disc in has been told to do the "open iTunes" action every time. To change this, go to the Apple Menu -> System Preferences, CDs & DVDs (should be in the upper left corner of the window), and make sure that the "When you insert a blank CD" and "blank DVD" both say "Ask me what to do" next to them - if not, then change it so that they do. Now, it anytime you pop in a blank disc, it will ask you what to do, and you can tell it "open with Finder" when needed, or "open with iTunes" if you want to open it in there.
Nov 15, 2009 | Computers & Internet
Need 25-character Vista key to buy backups from MS!
Hello John,
Unfortunately none of the PC manufacturers, with the exception of Toshiba and Dell, ship with recovery disks anymore. Instead, you have the option to create recovery disks after you purchase the computer. HP for example, used 3 DVD-R's to create recovery disks. And when you use those discs to recover your system it will revert it back to the way it was when you purchased it. So unfortauntely, the only way to get a set of recovery discs is to purchase them from HP. They cost about $30 on average. And unless you want to just purchase a new full copy of windows, purchasing the recovery discs are the only way to recover your system... legally.
To order HP's discs, just go to their support site at www.hp.com and search for your model number. It will then give you the instructions on how to order your specific discs.
May 05, 2008 | Microsoft Windows Vista Ultimate Edition
Terapin TX-0002 CD-R Burner Logo
52 people viewed this question
Top Terapin Computers & Internet Experts
David Payne
David Payne
Are you a Terapin Computer and Internet Expert? Answer questions, earn points and help others
