Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
My FrigidareY dishwasher will have water surfacing in the bottom of it within 2 to 3 days after I use it.. I have replaced the disposal twice and keep getting this problem. What is the problem?
    Sergeant:
    Champion:
  • 351 Answers
Water valve maybe letting water in.if so need to be replace or drain backing up
Posted on Oct 01, 2010
The unit works, but if the water level gets too high, while operating, it begins to drip from the bottom of the unit. Nothing on the exterior is wet. Can it be fixed, or should I replace it? Where can I...
Where is leak coming from?
From the pipes or from bottom of disposal?
If leak is coming from tubular drain pipe or around dishwasher connection, then clean out disposal and repair connections.
If leak is at bottom of disposal, then disposal is probably rusted out and needs replacement.
To solve high water issue and leaking pipes.
Loosen 2 nuts on P-trap and trap falls loose. Then remove tailpiece that connects to side of disposal. Hang rag over opening on side of disposal so water is directed downward, then turn on water and disposal and flush out the clog. Clean trap and tubular drain, and then reassemble.
I wrote ez disposal replacement steps, that also show how to take apart and reassemble tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The plug on the bottom of the garbage desposal is loose and water is coming out
It sounds like the disposal is rusted out if water comes out the bottom.
Check top and sides to see if water is seeping down from the sink strainer of dishwasher connection.
Check tailpiece to see is drain is leaking.
If disposal is rusted, it has to be replaced.
I wrote ez steps from days I worked apartment maintenance.
Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water will not drain form bottom of waqsher. I did just change the garbage disposal the other day - could that have something to do with it?(properly0
Did you knock the plug out of the disposal???
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 29, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher filling with water when not in use.
you need to replace the fill valve located on the left side behind the kick plates located at the bottom of machine. But you can test this by turning off valve located under the sink.
However if the disposal is clogged its possible that water is back filling as it usaully drains through the disposal. Also make sure that the drain hose has'nt fallen below p-trap of sink.
Jul 12, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My Maytag quiet series 200 is a good dish holder but certainly does not wash dishes - tried different soap all settings only result - dirty dishes - ready to throw it out -
do you have a watersoftner if so may not be working properly if its ok then do you always have water sitting in bottom of tub area. try this fill sink with water on disposal side 1/2 the way open door to dishwasher remove the stopper turn on the disposal do you see water or movement in the tub of the dishwasher if so replumb so the drain does not come into the disposal and plug the disposal opening
Aug 19, 2009 | Dishwashers
Once my dishwasher completed the cycle there is no water but after two or three days the bottom of the dishwasher fills with the dirty water. what could be the reason? I have garbage disposal and one pipe...
You must have your dishwasher connected directly to the garbage disposal and not through an air gap. What is happening is when you disposal fills with water it is siphoning through the drain hose back to the dishwasher. If you sink has a spare hole on the deck install air gap and run dishwasher drain through air gap first. Otherwise make sure you run Garbage disposal often so that water does not get slowed and build up inside.
May 11, 2009 | Frigidaire 24 in. FDBB944C Built-in...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
42 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
