Question about Ovens
After using the 2 hr. speed clean cycle on this range successfully, I went to bake in it several hrs. later to find that oven barely gets warm . I can set temp and indicators show elements "on" but thats it. Console shows no error codes and all range top quartz elements work fine. This appliance is 18 months old and has seen moderate use. Fridgedaire Model FEFL79JCA
    Sergeant:
    Champion:
  • 351 Answers
Bake element may have stop working wire burnt off or bad element that where i would start looking
Posted on Oct 01, 2010
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Electric range/oven switched from bake to self-clean without my help!
Good Afternoon Mr Oliver!
Often, if Whirlpool oven starts to do things on its own.. the touchpad might be failing or faulty. Keys fail and short, meaning they think they're being pressed when they actually aren't. Do you have the model number of you oven?
May 17, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Oven is not getting hot only warm
You may have a failed bake element, and the reason why the oven is only getting warm is the Broil element is cycling only. You may be able to remove the element and ask your local parts store to test it for continuity.
Aug 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
